Thanks again Lee Mac!! But how to find crossing points then?
  • 5 months later...
  • Replies 31
  • phoenix2009
    10
  • Lee Mac
    7
  • irneb
    5
  • zamri_uut
    3
Posted Images
zami: Your request is somewhat lacking in detail. Could you elaborate further?
  zamri_uut said:
Sorry Mr. Lee Mac, please help me !
Which code post are you referring to (#15 / #16 / #20)?
Sorry for my english... Post #16.. The line is crossing.. Thanks.
Try this modification:
([color=BLUE]defun[/color] c:test ( [color=BLUE]/[/color] a1 d1 d2 d3 e1 e2 p1 p2 sp xl zv )
   ([color=BLUE]if[/color]
       ([color=BLUE]and[/color]
           ([color=BLUE]setq[/color] e1 (LM:ssget [color=MAROON]"\nSelect 1st Polyline: "[/color] '([color=MAROON]"_+.:E:S"[/color] ((0 . [color=MAROON]"LWPOLYLINE"[/color])))))
           ([color=BLUE]setq[/color] e2 (LM:ssget [color=MAROON]"\nSelect 2nd Polyline: "[/color] '([color=MAROON]"_+.:E:S"[/color] ((0 . [color=MAROON]"LWPOLYLINE"[/color])))))
           ([color=BLUE]progn[/color]
               ([color=BLUE]initget[/color] 6)
               ([color=BLUE]setq[/color] d1 ([color=BLUE]getdist[/color]  [color=MAROON]"\nSpecify Step Distance: "[/color]))
           ([color=BLUE]setq[/color] d3 ([color=BLUE]-[/color] d1)
                 e1 ([color=BLUE]ssname[/color] e1 0)
                 e2 ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]ssname[/color] e2 0))
                 d2 ([color=BLUE]vlax-curve-getdistatparam[/color] e1 ([color=BLUE]vlax-curve-getendparam[/color] e1))
                 zv ([color=BLUE]trans[/color] '(0.0 0.0 1.0) 1 0 [color=BLUE]t[/color])
                 sp ([color=BLUE]vlax-get-property[/color] ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color]))
                        ([color=BLUE]if[/color] ([color=BLUE]=[/color] 1 ([color=BLUE]getvar[/color] 'cvport)) 'paperspace 'modelspace)
           ([color=BLUE]while[/color] ([color=BLUE]<=[/color] ([color=BLUE]setq[/color] d3 ([color=BLUE]+[/color] d3 d1)) d2)
               ([color=BLUE]setq[/color] p1 ([color=BLUE]vlax-curve-getpointatdist[/color] e1 d3)
                     a1 ([color=BLUE]-[/color] ([color=BLUE]angle[/color] '(0.0 0.0) ([color=BLUE]trans[/color] ([color=BLUE]vlax-curve-getfirstderiv[/color] e1 ([color=BLUE]vlax-curve-getparamatpoint[/color] e1 p1)) 0 1)) ([color=BLUE]/[/color] [color=BLUE]pi[/color] 2.0))
                     xl ([color=BLUE]vlax-invoke[/color] sp 'addxline p1 ([color=BLUE]trans[/color] ([color=BLUE]polar[/color] ([color=BLUE]trans[/color] p1 0 1) a1 1.0) 1 0))
                   ([color=BLUE]setq[/color] p2
                       ([color=BLUE]car[/color]
                           ([color=BLUE]vl-sort[/color] (LM:group3 ([color=BLUE]vlax-invoke[/color] xl 'intersectwith e2 [color=BLUE]acextendthisentity[/color]))
                              '([color=BLUE]lambda[/color] ( a b ) ([color=BLUE]<[/color] ([color=BLUE]distance[/color] a p1) ([color=BLUE]distance[/color] b p1)))
                       ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"LINE"[/color]) ([color=BLUE]cons[/color] 10 p1) ([color=BLUE]cons[/color] 11 p2)))
                              '(0 . [color=MAROON]"TEXT"[/color])
                               ([color=BLUE]cons[/color] 10 ([color=BLUE]trans[/color] p1 0 zv))
                               ([color=BLUE]cons[/color] 11 ([color=BLUE]trans[/color] p1 0 zv))
                               ([color=BLUE]cons[/color] 50 ([color=BLUE]+[/color] a1 ([color=BLUE]angle[/color] '(0.0 0.0) ([color=BLUE]trans[/color] ([color=BLUE]getvar[/color] 'ucsxdir) 0 zv [color=BLUE]t[/color]))))
                               ([color=BLUE]cons[/color] 40 ([color=BLUE]getvar[/color] 'textsize))
                               ([color=BLUE]cons[/color] 07 ([color=BLUE]getvar[/color] 'textstyle))
                               ([color=BLUE]cons[/color] 01 ([color=BLUE]strcat[/color] [color=MAROON]"L="[/color] ([color=BLUE]rtos[/color] ([color=BLUE]distance[/color] p1 p2) 2) [color=MAROON]"m"[/color]))
                              '(72 . 0)
                              '(73 . 2)
                               ([color=BLUE]cons[/color] 210 zv)
               ([color=BLUE]vla-delete[/color] xl)
   ([color=BLUE]princ[/color])
([color=BLUE]defun[/color] LM:group3 ( lst [color=BLUE]/[/color] rtn )
   ([color=BLUE]repeat[/color] ([color=BLUE]/[/color] ([color=BLUE]length[/color] lst) 3)
       ([color=BLUE]setq[/color] rtn ([color=BLUE]cons[/color] ([color=BLUE]list[/color] ([color=BLUE]car[/color] lst) ([color=BLUE]cadr[/color] lst) ([color=BLUE]caddr[/color] lst)) rtn)
             lst ([color=BLUE]cdddr[/color] lst)
   ([color=BLUE]reverse[/color] rtn)
[color=GREEN];; ssget  -  Lee Mac[/color]
[color=GREEN];; A wrapper for the ssget function to permit the use of a custom selection prompt[/color]
([color=BLUE]defun[/color] LM:ssget ( msg params [color=BLUE]/[/color] sel )
   ([color=BLUE]princ[/color] msg)
   ([color=BLUE]setvar[/color] 'nomutt 1)
   ([color=BLUE]setq[/color] sel ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]ssget[/color] params))
   ([color=BLUE]setvar[/color] 'nomutt 0)
   ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]vl-catch-all-error-p[/color] sel)) sel)
([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color])
Well done ! Thank you Mr. Lee Mac... You are the best..!
  • 10 months later...
Thanks for your lisp in Post #26.But in this lisp the dimension is not written at the start and the end of the polyline.First dimension is written after the specified step distance.Is it possible to add dimensions to start and the end of the polyline?
Thanks
Umit
The dimensions will start at the startpoint of the first polyline selected, and will continue until the step distance exceeds the length of this first polyline.
  • 9 months later...
Hi,
I have many longitudinal profile (hundreds).
This Longitudinal Profile is made using the program URBANO-Canalis.
What should I do is to extract the depth of excavation.
If trim the line the text change of field line length (blue color).
I am attaching an sample.
All the best.
Best Regards,
Doru
Depth Category.dwgFetching info...
Edited by doru10
Hi mister Lee,
Is a very good Lisp but help me more if value should be field - line lenght.
All the best.
Best Regards,
Doru
  • 9 years later...
Hello, cand you please provide the full lisp? Thank You
