Reu Posted February 1, 2013 Share Posted February 1, 2013 (defun gp:getPointInput (/ StartPt EndPt HalfWidth) (if (setq StartPt (getpoint "\nStart point of path: ")) (if (setq EndPt (getpoint StartPt "\nEndpoint of path: ")) (if (setq HalfWidth (getdist EndPt "\nhalf-width of path: ")) T ) ) ) ) I thought the syntax for the if function was: (if (test expression) (expression) (optional expression) ) What is the purpose of using 'if' in the above code? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 1, 2013 Share Posted February 1, 2013 The intent may be clearer with better indentation: (defun gp:getPointInput ( / StartPt EndPt HalfWidth ) (if (setq StartPt (getpoint "\nStart point of path: ")) (if (setq EndPt (getpoint StartPt "\nEndpoint of path: ")) (if (setq HalfWidth (getdist EndPt "\nhalf-width of path: ")) T ) ) ) ) Here, the 'then' expressions for the first and second if statements are the second and third if statements respectively; though, the code is rather pointless since the 'then' expression for the final if statement is simply returning a boolean true value without using the collected points and distance values. Quote Link to comment Share on other sites More sharing options...
Reu Posted February 1, 2013 Author Share Posted February 1, 2013 The intent may be clearer with better indentation: ;;; Function gp:getPointInput will get path location and size (defun gp:getPointInput (/ StartPt EndPt HalfWidth) (if (setq StartPt (getpoint "\nStart point of path: ")) (if (setq EndPt (getpoint StartPt "\nEndpoint of path: ")) (if (setq HalfWidth (getdist EndPt "\nhalf-width of path: ")) (list StartPt EndPt HalfWidth) ) ) ) ) This is better? I've recently discovered the AutoLISP tutorial (that is where the code is from. I was asking about 'if' used as shown above because I have seen it so done before and wondered why. It didn't make sense when I was looking for something like: (if (this statement is true) (do this) (else do this) So essentially the 'test expression' for the first 'if' is "(getpoint "\nStart point of path: ")", the 'expression' to be evaluated if the 'test expression' returns a non-nil value is "(setq StartPt)", and the 'else' expression would be anything done by the user (eg. pressing 'Enter') that returns a nil value. Am I correct? Quote Link to comment Share on other sites More sharing options...
MSasu Posted February 1, 2013 Share Posted February 1, 2013 Lee Mac just formatted your code excerpt to help you understand the logical succession. I will try to add comments to it, maybe this will help you more: (defun gp:getPointInput ( / StartPt EndPt HalfWidth) (if (setq StartPt (getpoint "\nStart point of path: ")) ;1 (if (setq EndPt (getpoint StartPt "\nEndpoint of path: ")) ;2 (if (setq HalfWidth (getdist EndPt "\nhalf-width of path: ")) ;3 (list StartPt EndPt HalfWidth) ;4 ) ) ) ) test if user picked a point or entered a set of coordinates; if succesful, go to next test. test if user picked another point or entered a set of coordinates; if succesful, go to next test. test if user picked a point (AutoCAD return measured distance between second point and current pick) or inputted a distance (numerical value). if all three above inputs were valid (all tests were passed) the routine return a list with 1st and 2nd point, respectively the numerical value. Mybe this formatting make more sense for you? (defun gp:getPointInput ( / StartPt EndPt HalfWidth) (if (and (setq StartPt (getpoint "\nStart point of path: ")) (setq EndPt (getpoint StartPt "\nEndpoint of path: ")) (setq HalfWidth (getdist EndPt "\nhalf-width of path: "))) (list StartPt EndPt HalfWidth) ) ) Quote Link to comment Share on other sites More sharing options...
MSasu Posted February 1, 2013 Share Posted February 1, 2013 I also annotated your code analisys: So essentially the 'test expression' for the first 'if' is "(getpoint "\nStart point of path: ")", the 'expression' to be evaluated if the 'test expression' returns a non-nil value is "(setq StartPt)", and the 'else' expression would be anything done by the user (eg. pressing 'Enter') that returns a nil value. So essentially the 'test expression' for the first 'if' is "(getpoint "\nStart point of path: ")" [true], the 'expression' to be evaluated if the 'test expression' returns a non-nil value is "(setq StartPt)", a new input test and the 'else' expression swould be anything done by the user (eg. pressing 'Enter') that returns a nil value. is not present into this piece of code; it does nothing if input is invalid or cancelled (more precisely the routine will return nil). Quote Link to comment Share on other sites More sharing options...
Reu Posted February 1, 2013 Author Share Posted February 1, 2013 Mybe this formatting make more sense for you? (defun gp:getPointInput ( / StartPt EndPt HalfWidth) (if (and (setq StartPt (getpoint "\nStart point of path: ")) (setq EndPt (getpoint StartPt "\nEndpoint of path: ")) (setq HalfWidth (getdist EndPt "\nhalf-width of path: "))) (list StartPt EndPt HalfWidth) ) ) Yes, thanks. So when you do multiple 'if' statements it is the same thing as a single 'if' statement with multiple 'and' test expressions. Quote Link to comment Share on other sites More sharing options...
MSasu Posted February 2, 2013 Share Posted February 2, 2013 There is a difference; using nested IF's will be able to define a specific action for each invalid input, while combining the tests with AND the action will be common. Please test in VLISP Console the two excerpts of code below: (if (setq var1st (getint "\nFirst number: ")) (if (setq var2nd (getint "\nSecond number: ")) (alert "All inputs valid!") (alert "No 2nd input!") ) (alert "No 1st input!") ) (if (and (setq var1st (getint "\nFirst number: ")) (setq var2nd (getint "\nSecond number: "))) (alert "All inputs valid!") (alert "No inputs!") ) Quote Link to comment Share on other sites More sharing options...
