Hi, I am trying to run a numerical analysis with a finite element method, so I want to model two intersecting tunnels with the real terreain elevations; I really dont know to much the use of rhinos... So the things I want to know, are:
1.- Having the TOPOGRAPHY, via coordinates or curves, How can I import them to rhinos? and then its possible to create a solid with them???
If so, can I give to the solid just created a "personalized depth"??? and finally I will insert the tunnels and use booleans operations..
Am I right??
2.- Is there a easiest way to model the terrain in rhinos???
Thank you, for reading this and hope you can help me..... Saludos.
