Looking for a quick fix. I need to bisect a line and draw a perpendicular line from the mid-point of the measure line. It would be great if this could be dynamically done i.e. the perpendicular can be drawn either side of the line and to any length.
Any assists will abe appreciated.
In your OSNAPs set midpoint and perpendicular. Turn dynamic input on. Press F11 to toggle "object snap trace" on (I think that's what its called in English versions, if not look in the bottem left of the screen and observe and you'll see an icon go on and off, make sure that it is on). Start the line command and snap to the mid point of the line and as you move your cursor away you will get a dotted line and you just need to enter the length of the line and you have exactly what you wished for.
Just follow Tyke's instructions and you will be a very happy camper. :beer:
The 3 ICONS which are circled in the image are those to which Tyke refers
they are OBJECT SNAPS, OBJECT SNAP TRACKING and DYNAMIC INPUT from left to right.
They can be left clicked to turn them on or off,
or they can be toggled on and off with F3, F11 & F12 respectively.
Thanks Tyke that works great but I was looking for a lisp routine, as I have loads of lines to draw perpendiculars to.
Use this old program and click the midpoint:
(defun c:per ( / *error* e o p )
   (defun *error* ( m )
       (if o (progn (setvar 'orthomode o) (command "_.ucs" "_p")))
   (if (and
           (setq p (getpoint "\nSpecify first point: "))
           (setq e (car (nentselp p)))
           (setq p (trans p 1 0))
           (command "_.ucs" "_ob" e)
           (setq o (getvar 'orthomode))
           (setvar 'orthomode 1)
           (command "_.line" "_non" (trans p 0 1))
           (while (< 0 (getvar 'cmdactive)) (command "\\"))
   (if (and
That's neat Lee. :thumbsup: With Dynamic Input turned on can you type in the line length?
Alternatively,
(defun c:per ( / e p q )
   (if (setq e (ssget "_+.:E:S" '((0 . "LINE"))))
           (setq e (entget (ssname e 0))
                 p (trans (cdr (assoc 10 e)) 0 1)
                 q (trans (cdr (assoc 11 e)) 0 1)
           (vl-cmdf "_.line" "_non"
               (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) p q)
               (strcat "<" (angtos (+ (angle p q) (/ pi 2.0))))
Cheers Tyke - yes, you should still be able to type the line length :thumbsup:
Thanks Lee and all those who have contributed, appreciated.
Another with grread and grdraw functions . just for fun . :)
(defun c:Test (/ s p ang g st nd pt)
;;; Tharwat 25. Jan. 2013 ;;;
 (if (and (setq s (car (entsel "\n Select line :")))
          (eq (cdr (assoc 0 (entget s))) "LINE")
     (setq p   (mapcar (function (lambda (j k) (/ (+ j k) 2.)))
                       (setq st (cdr (assoc 10 (entget s))))
                       (setq nd (cdr (assoc 11 (entget s))))
           ang (angle st nd)
     (while (eq (car (setq g (grread t 15 0))) 5)
       (redraw)
       (grdraw p
               (setq pt (polar p
                               (+ ang (* pi 0.5))
                               (if (> 0 (sin (- (angle st (cadr g)) ang)))
                                 (- (distance p (cadr g)))
               1
               0
     (if (or (eq (car g) 3)
             (eq (car g) 25)
       (entmakex
         (list '(0 . "LINE") (cons 10 (trans p 1 0)) (cons 11 pt))
 (redraw)
Edited by Tharwat
small problem with the angle modified with the help of Lee
(defun c:Test (/ s p g st nd pt)
Good attempt Tharwat, but not quite:
Consider perhaps something like:
([color=BLUE]defun[/color] c:test ( [color=BLUE]/[/color] a b d e g m p q )
   ([color=BLUE]if[/color] ([color=BLUE]setq[/color] e ([color=BLUE]ssget[/color] [color=MAROON]"_+.:E:S"[/color] '((0 . [color=MAROON]"LINE"[/color]))))
       ([color=BLUE]progn[/color]
           ([color=BLUE]setq[/color] e ([color=BLUE]entget[/color] ([color=BLUE]ssname[/color] e 0))
                 p ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 e)) 0 1)
                 q ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 11 e)) 0 1)
                 m ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( a b ) ([color=BLUE]/[/color] ([color=BLUE]+[/color] a b) 2.0)) p q)
                 a ([color=BLUE]angle[/color] p q)
                 b ([color=BLUE]+[/color] a ([color=BLUE]/[/color] [color=BLUE]pi[/color] 2.0))
           ([color=BLUE]while[/color] ([color=BLUE]=[/color] 5 ([color=BLUE]car[/color] ([color=BLUE]setq[/color] g ([color=BLUE]grread[/color] [color=BLUE]t[/color] 13 0))))
               ([color=BLUE]redraw[/color])
               ([color=BLUE]setq[/color] g ([color=BLUE]cadr[/color] g)
                     d ([color=BLUE]distance[/color] m g)
                     q ([color=BLUE]polar[/color] m b ([color=BLUE]if[/color] ([color=BLUE]<[/color] 0 ([color=BLUE]sin[/color] ([color=BLUE]-[/color] ([color=BLUE]angle[/color] p g) a))) d ([color=BLUE]-[/color] d)))
               ([color=BLUE]grdraw[/color] m q -1)
           ([color=BLUE]if[/color] ([color=BLUE]=[/color] 3 ([color=BLUE]car[/color] g))
               ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"LINE"[/color]) ([color=BLUE]cons[/color] 10 ([color=BLUE]trans[/color] m 1 0)) ([color=BLUE]cons[/color] 11 ([color=BLUE]trans[/color] q 1 0))))
   ([color=BLUE]redraw[/color]) ([color=BLUE]princ[/color])
Nice coding Tharwat, thanks.
You're welcome . and really happy to hear that. :)
  • 2 years later...
insted of line is there any way to get Linear Dimension?
or line with dimensions.
A simple macro to rotate the UCS to the line is a very simple way to do all the above.
^C^CUCS Object
And another to put it back
^C^CUCS World
