Hi,
I was wondering if it was possible to offset the single side / row of an object
here a rectangle.
Thanks
You could Offset one side if the rectangle was comprised of separate lines or polylines. I almost get the impression you want to move that one side in which case Stretch would be the command you want.
I used object to make that rectangle, now i'm using the line tool to recreate the rectangle and its ok I can offset every part of it as I want.
Thx
Thx
You could have simply Exploded the rectangle - I can't imagine it is very efficient to create a rectangle line-by-line.
Explode the rectangle? didnt know about that function I'll Google it thx!
You don't have to Google it as your Help file will tell you what you need to know about the Explode command. You have a resource at your fingertips. Use it.
