Thanks. It is probably time I got around to learning lisp.
  • Replies 50
  • Organic
    8
  • Lee Mac
    7
  • ReMark
    5
  • pkenewell
    4
Posted Images
  Organic said:
How do I divide the area by a factor? E.g. if I wanted to divide it by a factor 10
In mine, change:
([color=BLUE]cons[/color] 01 ([color=BLUE]rtos[/color] ([color=BLUE]vla-get-area[/color] ([color=BLUE]vlax-ename->vla-object[/color] e))))
to:
([color=BLUE]cons[/color] 01 ([color=BLUE]rtos[/color] [highlight]([color=blue]/[/color][/highlight] ([color=BLUE]vla-get-area[/color] ([color=BLUE]vlax-ename->vla-object[/color] e)) [highlight]10.0)[/highlight]))
  • 2 weeks later...
thanx 4 ur effort GP, hope u willing 2 help me to get this: i've modified ur lisp so it gives me area in acre format but how to make additional format such as area in hactare under the area in acre so then the area has two area information which are acre and hactare..
Just another solution maybe.
You could use a mtext field so that when you modify the polyline you get the new area with out running the lisp again.
Try MTEXT.
(setq t1 "acres")    ;enter string acres value
(setq t2 "hectares") ;enter string hectares value
(setq txt (strcat t1 "[url="file://\\P"]\\P[/url]" t2))
(entmake
   (list
       (cons 0 "MTEXT")
       (cons 8 (getvar "clayer"))
       (cons 100 "AcDbEntity")
       (cons 100 "AcDbMText")
       (cons 7 (getvar "textstyle"))
       (cons 10 P_center)
       (cons 71 5)
       (cons 1 txt)
special thanx 4 GP wiling to share..
  Lee Mac said:
Try this quickly written program, based on my Area Label program:
([color=BLUE]defun[/color] c:quickarea ( [color=BLUE]/[/color] *error* c e l p v x )
   ([color=BLUE]defun[/color] *error* ( msg )
       ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'int ([color=BLUE]type[/color] v))
           ([color=BLUE]setvar[/color] 'cmdecho v)
       ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'ename ([color=BLUE]type[/color] e))
           ([color=BLUE]entdel[/color] e)
       ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]wcmatch[/color] ([color=BLUE]strcase[/color] msg) [color=MAROON]"*BREAK,*CANCEL*,*EXIT*"[/color]))
           ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nError: "[/color] msg))
       ([color=BLUE]princ[/color])
   ([color=BLUE]setq[/color] v ([color=BLUE]getvar[/color] 'cmdecho))
   ([color=BLUE]setvar[/color] 'cmdecho 0)
   ([color=BLUE]while[/color] ([color=BLUE]setq[/color] p ([color=BLUE]getpoint[/color] [color=MAROON]"\nPick Area <Exit>: "[/color]))
           ([color=BLUE]progn[/color]
               ([color=BLUE]setq[/color] e [color=BLUE]nil[/color])
       ([color=BLUE]setq[/color] x ([color=BLUE]entlast[/color]))
       ([color=BLUE]command[/color] [color=MAROON]"_.-boundary"[/color] [color=MAROON]"_A"[/color] [color=MAROON]"_B"[/color] [color=MAROON]"_E"[/color] [color=MAROON]"_I"[/color] [color=MAROON]"_N"[/color] [color=MAROON]""[/color] [color=MAROON]"_O"[/color] [color=MAROON]"_P"[/color] [color=MAROON]""[/color] [color=MAROON]"_non"[/color] p [color=MAROON]""[/color])
           ([color=BLUE]and[/color]
               ([color=BLUE]not[/color] ([color=BLUE]eq[/color] x ([color=BLUE]setq[/color] e ([color=BLUE]entlast[/color]))))
               ([color=BLUE]=[/color] [color=MAROON]"LWPOLYLINE"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 ([color=BLUE]entget[/color] e))))
               ([color=BLUE]foreach[/color] x ([color=BLUE]entget[/color] e)
                   ([color=BLUE]if[/color] ([color=BLUE]=[/color] 10 ([color=BLUE]car[/color] x))
                       ([color=BLUE]setq[/color] l ([color=BLUE]cons[/color] ([color=BLUE]cdr[/color] x) l))
               ([color=BLUE]setq[/color] c ([color=BLUE]mapcar[/color] '[color=BLUE]/[/color] ([color=BLUE]apply[/color] '[color=BLUE]mapcar[/color] ([color=BLUE]cons[/color] '[color=BLUE]+[/color] l)) ([color=BLUE]list[/color] ([color=BLUE]length[/color] l) ([color=BLUE]length[/color] l))))
               ([color=BLUE]entmake[/color]
                      '(0 . [color=MAROON]"TEXT"[/color])
                       ([color=BLUE]cons[/color] 40 ([color=BLUE]getvar[/color] 'textsize))
                       ([color=BLUE]cons[/color] 07 ([color=BLUE]getvar[/color] 'textstyle))
                       ([color=BLUE]cons[/color] 10 c)
                       ([color=BLUE]cons[/color] 11 c)
                      '(72 . 1)
                      '(73 . 2)
               ([color=BLUE]redraw[/color] e 3)
               ([color=BLUE]setq[/color] l [color=BLUE]nil[/color])
([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color])
Lee, I sure can't get this to work. Does it work for others ? using vanilla AC2008. TIA, Steve
Hi Steve, the code works well in my brief tests - what error do you receive, if any?
Lee, dummy me, I had frozen a layer after testing program.... all is well. code works fine. my stupidity...distraction.
Thx, Steve
  • 4 months later...
                      '(72 . 1)
                      '(73 . 2)
I found myself needing this again and found this thread via Google :)
Is it an easy change to make the lisp give the area to 2dp instead of 3dp?
Change:
to:
([color=BLUE]cons[/color] 01 ([color=BLUE]rtos[/color] ([color=BLUE]vla-get-area[/color] ([color=BLUE]vlax-ename->vla-object[/color] e)) [highlight]2 2[/highlight]))
Much appreciated, cheers.
  • 2 years later...
  fixo said:
Hmm too many letters, here is mine
(defun C:LHAT(/ ar cp en hobj lp num rp sset)
 (if (and
(setq lp (getpoint "\nFirst Corner point of selection window >> ")
     rp (getcorner lp "\nOpposite Corner >> "))
(setq sset (ssget "_W" lp rp (list
         (cons 0 "hatch")
         ;; hatch patterns separated by comma
         (cons 2 "ANGLE,DOLMIT,ANSI37,AR-BRELM,AR-RSHKE"); you may exclude this one to grab all hatches
(setq num (sslength sset))
 (while (> num 0)
   (setq en (ssname sset (setq num (1- num))))
   (setq hobj (vlax-ename->vla-object en)
  ar (vla-get-area hobj))
(setq cp (trans (cdr (last (entget en))) en 0))
   (command "._mtext"  cp "_h" 2.5 "_j" "_mc" "_w" 0 (rtos ar 2 0) "")
(or (vl-load-com)(princ))
Hey FIXO how do I modify this to change the precision of results? I need it to give me measurement to the 100th.
THANKS
Ah jeez, if you're still listening... what exactly needs to be removed for it to work with all hatches? I've added ANSI31, wont work. I took off the line in parenthesis... don't work...
THANKS
i usually place on hatched area mline text, open text window and insert field (field category: objects; field names: object; object type: pick on the drawing, property:area).
if you copy both of them- hatch object and text with field, then paste, stretch new hatch object and use command regen or just save drawing, you'll see, that field will change and showing area of new hatched object.
Hey man that works pretty good! Thanks for the tip. Works well, but unfortunately it's not practical for me to do my task that way... I have close to one hundred hatches, three different types, and varying sizes, so the lisp routine is ideal and fast, but I can only get it to function on two of the three hatch patterns.
