Dear Experts,
I currently obtained a building plan map with rooms, doors, stairs,etc. My task is to extract the doors and tranform it as point. The doors have been represented as a connected arc and two lines. The size of map is fairly large and there is quite a lot of arcs, and so I have to use LISP to automatically extract the arcs based on specific algorithm.
My current problems is quite simple: how to loop all drawing entities and extract the type of entities that I want? I want to know the AutoCAD commands, and if your can provide the algorithm, would be very appreciated!
Many thanks for your help! :lol:
(ssget) will be your friend here
You can filter for entity type ("ARC") and layers ("0") if applicable
A little more detail may help with your request.
-David
