Rubbersnow Posted January 16, 2013 Posted January 16, 2013 hey guys, I have little problem. I'm trying to draw ventilation in 3D ,and I have reached a point where two air ducts with different sizes must connect to each other,so basically I need to draw a reduction from 1000/200mm to 700/300mm. I tryed to draw it manually via lines and then to make a block of it, and it's working ,but when I use the HIDE command I still can see trough it. Any ideas? Quote
MSasu Posted January 16, 2013 Posted January 16, 2013 You should draw the sections at both ends with respect for their relative location and apply the LOFT command on them. Quote
Rubbersnow Posted January 16, 2013 Author Posted January 16, 2013 it's exactly what I wanted to do. working perfect. thank you very much Quote
