Hi all
We have drawings containing Multi-Leaders that have their bounding boxes way too big! Too bigger than what the text is contained in the bounding box.
We do have a lisp that can re-size the bounding box for MTEXT entities, but this does not work for Multi-Leaders text.
Does anyone already have a lisp that does this and are willing to share?
It will be very much appreciated if anyone can assist.
Regards
Shoey
Try this simple code ...
(defun c:Test (/ e i n)
 (if (setq e (ssget "_:L" '((0 . "MULTILEADER"))))
   (repeat (setq i (sslength e))
     (setq n (ssname e (setq i (1- i))))
     (entmod (subst '(43 . 0.) (assoc 43 (entget n)) (entget n)))
Thanks very much Tharwat.
I appreciate your code. However, i forgot to mention that we have multiple lines of text contained within our multi-leaders.
We need to retain these lines of text and keep the width and height of the bounding box the same.
We do not wish to convert them into a single line of text.
Regards
Shoey
Try the following Shoey:
[color=GREEN];; Fit MLeader MText Frame  -  Lee Mac[/color]
([color=BLUE]defun[/color] c:mlf ( [color=BLUE]/[/color] e f i l s )
   ([color=BLUE]defun[/color] f ( e [color=BLUE]/[/color] i l s x )
       ([color=BLUE]setq[/color] s ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 304 e))
             x ([color=BLUE]list[/color]
                   ([color=BLUE]cons[/color] 40 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 41 e)))
                   ([color=BLUE]cons[/color] 07 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 02 ([color=BLUE]entget[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 340 e))))))
       ([color=BLUE]while[/color] ([color=BLUE]setq[/color] i ([color=BLUE]vl-string-search[/color] [color=MAROON]"\\P"[/color] s))
           ([color=BLUE]setq[/color] l ([color=BLUE]cons[/color] ([color=BLUE]substr[/color] s 1 i) l)
                 s ([color=BLUE]substr[/color] s ([color=BLUE]+[/color] i 3))
           ([color=BLUE]vl-remove-if[/color] '[color=BLUE]null[/color]
               ([color=BLUE]mapcar[/color]
                   ([color=BLUE]function[/color]
                       ([color=BLUE]lambda[/color] ( s [color=BLUE]/[/color] b )
                           ([color=BLUE]if[/color] ([color=BLUE]setq[/color] b ([color=BLUE]textbox[/color] ([color=BLUE]cons[/color] ([color=BLUE]cons[/color] 1 s) x)))
                               ([color=BLUE]mapcar[/color] '[color=BLUE]-[/color] ([color=BLUE]cadr[/color] b) ([color=BLUE]car[/color] b))
                   ([color=BLUE]cons[/color] s l)
           ([color=BLUE]*[/color] [highlight]1.01[/highlight] ([color=BLUE]apply[/color] '[color=BLUE]max[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]car[/color] l)))
           ([color=BLUE]+[/color] ([color=BLUE]apply[/color] '[color=BLUE]+[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]cadr[/color] l)) ([color=BLUE]*[/color] 0.68 ([color=BLUE]1-[/color] ([color=BLUE]length[/color] l))))
   ([color=BLUE]if[/color] ([color=BLUE]setq[/color] s ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color] '((0 . [color=MAROON]"MULTILEADER"[/color]))))
       ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]sslength[/color] s))
           ([color=BLUE]setq[/color] e ([color=BLUE]entget[/color] ([color=BLUE]ssname[/color] s ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i))))
                 l (f e)
           ([color=BLUE]entmod[/color]
               ([color=BLUE]subst[/color] ([color=BLUE]cons[/color] 43 ([color=BLUE]car[/color] l)) ([color=BLUE]assoc[/color] 43 e)
                   ([color=BLUE]subst[/color] ([color=BLUE]cons[/color] 44 ([color=BLUE]cadr[/color] l)) ([color=BLUE]assoc[/color] 44 e) e)
   ([color=BLUE]princ[/color])
Increase the [highlight]highlighted[/highlight] tolerance value if you find some text is still moved onto the next line.
Edited by Lee Mac
Lee
Many thanks for your code too.
Its nearly there but the bounding box for the height is not quite there.
Hopefully, the attached image will make more sense to what we require.
The left image is what we are finding in our drawings.
Users have been returning upon the end of the line instead of using fixed widths.
We have also found that either multiple returns have been added at the end, hence the space at the bottom, or the users ahve been clicking and stretching the grips.
The image on the right is what we would like to see after the lisp is run.
Your code fixes the width grip location, but not the height grip location.
Hope you can assist.
Regards
Shoey
Many thanks Lee.
Works a treat!
I appreciate your time and assistance.
Regards
Shoey
  • 2 years later...
                 l (f e)
Dear LeeMac
Can get the textbox or 4 vertex coordinates of Mleader ?
It's possible ?
@Lee Mac
Hi Lee , It's no possible ? :(
@Lee Mac
It could be possible if you have the patience to wait for me to respond ;)
Here's a draft of a function to determine the textbox of an MLeader with text content:
[color=GREEN];; MLeader Textbox  -  Lee Mac[/color]
[color=GREEN];; Returns four OCS points describing the textbox of the content for a given MLeader[/color]
[color=GREEN];; ent - [ent] MLeader entity[/color]
([color=BLUE]defun[/color] LM:mleadertextbox ( ent [color=BLUE]/[/color] bpt enx hgt jus lst mat org prp rot wid )
   ([color=BLUE]if[/color] ([color=BLUE]=[/color] [color=BLUE]acmtextcontent[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 172 ([color=BLUE]reverse[/color] ([color=BLUE]setq[/color] enx ([color=BLUE]entget[/color] ent))))))
       ([color=BLUE]progn[/color]
           ([color=BLUE]setq[/color] prp ([color=BLUE]list[/color] ([color=BLUE]cons[/color] 40 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 41 enx)))
                           ([color=BLUE]cons[/color] 07 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 02 ([color=BLUE]entget[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 340 enx))))))
                 lst ([color=BLUE]vl-remove-if[/color] '[color=BLUE]null[/color]
                            '([color=BLUE]lambda[/color] ( str [color=BLUE]/[/color] box )
                                 ([color=BLUE]if[/color] ([color=BLUE]setq[/color] box ([color=BLUE]textbox[/color] ([color=BLUE]cons[/color] ([color=BLUE]cons[/color] 1 str) prp)))
                                     ([color=BLUE]mapcar[/color] '[color=BLUE]-[/color] ([color=BLUE]cadr[/color] box) ([color=BLUE]car[/color] box))
                             (LM:str->lst ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 304 enx)) [color=MAROON]"\\P"[/color])
                 bpt ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 12 enx)) 0 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 11 enx)))
                 rot ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 042 enx))
                 jus ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 171 enx))
                 wid ([color=BLUE]apply[/color] '[color=BLUE]max[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]car[/color] lst))
                 hgt ([color=BLUE]+[/color] ([color=BLUE]apply[/color] '[color=BLUE]+[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]cadr[/color] lst)) ([color=BLUE]*[/color] 0.68 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 45 enx)) ([color=BLUE]1-[/color] ([color=BLUE]length[/color] lst))))
                 org ([color=BLUE]list[/color] ([color=BLUE]cond[/color] (([color=BLUE]member[/color] jus '(2 5 ) ([color=BLUE]/[/color] wid -2.0)) (([color=BLUE]member[/color] jus '(3 6 9)) ([color=BLUE]-[/color] wid))      (0.0))
                           ([color=BLUE]cond[/color] (([color=BLUE]member[/color] jus '(1 2 3)) ([color=BLUE]-[/color] hgt))      (([color=BLUE]member[/color] jus '(4 5 6)) ([color=BLUE]/[/color] hgt -2.0)) (0.0))
                 mat ([color=BLUE]list[/color]
                         ([color=BLUE]list[/color] ([color=BLUE]cos[/color] rot) ([color=BLUE]sin[/color] ([color=BLUE]-[/color] rot)) 0.0)
                         ([color=BLUE]list[/color] ([color=BLUE]sin[/color] rot) ([color=BLUE]cos[/color] rot)     0.0)
                        '(0.0 0.0 1.0)
           ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( p ) ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] (mxv mat p) bpt))
               ([color=BLUE]list[/color] org
                   ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] org ([color=BLUE]list[/color] wid   0))
                   ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] org ([color=BLUE]list[/color] wid hgt))
                   ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] org ([color=BLUE]list[/color] 0   hgt))
[color=GREEN];; String to List  -  Lee Mac[/color]
[color=GREEN];; Separates a string using a given delimiter[/color]
[color=GREEN];; str - [str] String to process[/color]
[color=GREEN];; del - [str] Delimiter by which to separate the string[/color]
[color=GREEN];; Returns: [lst] List of strings[/color]
([color=BLUE]defun[/color] LM:str->lst ( str del [color=BLUE]/[/color] pos )
   ([color=BLUE]if[/color] ([color=BLUE]setq[/color] pos ([color=BLUE]vl-string-search[/color] del str))
       ([color=BLUE]cons[/color] ([color=BLUE]substr[/color] str 1 pos) (LM:str->lst ([color=BLUE]substr[/color] str ([color=BLUE]+[/color] pos 1 ([color=BLUE]strlen[/color] del))) del))
       ([color=BLUE]list[/color] str)
[color=GREEN];; Matrix x Vector  -  Vladimir Nesterovsky[/color]
[color=GREEN];; Args: m - nxn matrix, v - vector in R^n[/color]
([color=BLUE]defun[/color] mxv ( m v )
   ([color=BLUE]mapcar[/color] '([color=BLUE]lambda[/color] ( r ) ([color=BLUE]apply[/color] '[color=BLUE]+[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]*[/color] r v))) m)
And a small test program:
([color=BLUE]defun[/color] c:test ( [color=BLUE]/[/color] e v )
   ([color=BLUE]if[/color] ([color=BLUE]setq[/color] e ([color=BLUE]ssget[/color] [color=MAROON]"_+.:E:S"[/color] '((0 . [color=MAROON]"MULTILEADER"[/color]))))
           ([color=BLUE]setq[/color] e ([color=BLUE]ssname[/color] e 0)
                 v ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 11 ([color=BLUE]entget[/color] e)))
           ([color=BLUE]foreach[/color] x (LM:mleadertextbox e)
               ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"POINT"[/color]) ([color=BLUE]cons[/color] 10 ([color=BLUE]trans[/color] x v 0))))
Dear LeeMac
8) Thanks a million. I do appreciate your timely help!
  • 9 months later...
In order to eliminate a step, is there a way to determine the boundaries of multileader text while place the multileader in the drawing?
  • 6 years later...
I know this is an old thread but on current versions of ACAD I get the following error when I run Lee Mac's Fit MLeader MText Frame code. Can anyone help me? Thanks.
bad argument type: numberp: nil :error#0
Edited by mcweb
  • 5 months later...
Still would like to try out Lee Mac's code. I get this error in ACAD 2022.
 ; error: bad argument type: numberp: nil
If you clean up the extra formatting it should work.
(defun c:mlf ( / e f i l s )
   (defun f ( e / i l s x )
       (setq s (cdr (assoc 304 e))
             x (list
                   (cons 40 (cdr (assoc 41 e)))
                   (cons 07 (cdr (assoc 02 (entget (cdr (assoc 340 e))))))
       (while (setq i (vl-string-search "\\P" s))
           (setq l (cons (substr s 1 i) l)
                 s (substr s (+ i 3))
       (setq l
           (vl-remove-if 'null
               (mapcar
                   (function
                       (lambda ( s / b )
                           (if (setq b (textbox (cons (cons 1 s) x)))
                               (mapcar '- (cadr b) (car b))
                   (cons s l)
       (list
           (* 1.01 (apply 'max (mapcar 'car l)))
           (+ (apply '+ (mapcar 'cadr l)) (* 0.68 (1- (length l))))
   (if (setq s (ssget "_:L" '((0 . "MULTILEADER"))))
       (repeat (setq i (sslength s))
           (setq e (entget (ssname s (setq i (1- i))))
                 l (f e)
           (entmod
               (subst (cons 43 (car l)) (assoc 43 e)
                   (subst (cons 44 (cadr l)) (assoc 44 e) e)
This tip may or may not be relevant. You can minimize the boundaries of multitext by double-clicking on the margin jig. See picture with before and after.
             x (list
       (setq l
           (vl-remove-if 'null
               (mapcar
                   (function
                       (lambda ( s / b )
                   (cons s l)
       (list
                 l (f e)
           (entmod
Thank you SLW210, I thought I cleaned it up, but I must have missed a bit of it. That works!
Edited by mcweb
