Hi all,
I would like to find the intersection point between below 3D Lines
Line1: (5.0,5.0,8.0) (10.0,10.0,5.0)
Line2: (5.0,5.0,4.0) (10.0,10.0,6.0)
Please any one let me know how can i find the intersection point(3D) between these Lines.
Regards,
Kumar.
(setq l1 (entmakex '((0 . "LINE") (10 5.0 5.0 8.0) (11 10.0 10.0 5.0)))
     l2 (entmakex '((0 . "LINE") (10 5.0 5.0 4.0) (11 10.0 10.0 6.0)))
(vlax-invoke
 (vlax-ename->vla-object l1)
 'IntersectWith
 (vlax-ename->vla-object l2)
 acExtendBoth ;or acExtendNone
another way:
(setq p1 '(5.0 5.0 8.0)
     p2 '(10.0 10.0 5.0)
     p3 '(5.0 5.0 4.0)
     p4 '(10.0 10.0 6.0)
(setq intpoint (inters p1 p2 p3 p4 nil))
Henrique
Thanks for the reply.
I thought these functions works on 2D only, It is good to here also works on 3D lines.
You're welcome, giskumar
Henrique
A bit more Inters is the original or plain jane lisp intersection command and intesectwith is the newer Vl version I would go down the VL version, intersectwith has 4 options that can be included as part of the test for an intersection, inters has 1 true or false. Intesectwith can calculate an intersection even if the lines do not cross calculating the new pt.
This may be a little undocumented but a time saver when typing you can replace intersect mode with 0 1 2 3
All enumerations will evaluate to either an integer or some other constant data type - hence the name; the protected symbol is merely used to give some meaning to an otherwise 'magic number' e.g. (eval acbylayer) = 256.
I strongly disagree with your suggested 'timesaver' as it will render code unreadable and completely defeats the self-documenting purpose of the enumeration symbol.
  • Dislike 1
