JamFam Posted January 4, 2013 Posted January 4, 2013 Greetings to all. I would like some help in how to create a switch plate dynamic block. I can draw the light switch inside block editor no problem. My Objective: To insert a single light switch plate block into a drawing and have the ability to stretch the block to increase the number of switches from 1 to as many as 10 in a gang style. The light switch box would do a basic stretch, but I just can't figure out how to increase the number of switches as the block increases in width. I hope this makes sense. Thanks Quote
dbroada Posted January 4, 2013 Posted January 4, 2013 look into using the ARRAY action. This will array a number of objects when you stretch a set amount. It works best if you constrain your stretch with an increment that matches the array distance. Quote
JamFam Posted January 4, 2013 Author Posted January 4, 2013 I'll give it a try on my own first.Failing that, do you know if there is a tutorial anywhere that can show me how to use the array while making a dynamic block? Thanks Quote
