CAD89 Posted December 30, 2012 Posted December 30, 2012 Is there any way to make a lisp routine that can append all layers and styles of text existent in a drawing to a list?! I.E.: I have a drawing that has 5 different layers (let's say "0" "Dimensions" "Lines" "Text" and "Paper space"), and I want to make a lisp that searches through the dwg and appends the layers to a list ... is that possible? And I have about 3 text styles ("Standard" "Title" and "Date") and an empty list! How do I get my routine to find the text styles and store them into the empty list? Or it would be much better if I could make a list box containing all available fonts just to select one of them! Thanks in advance! With regards Csaba Arpad Dobai! Quote
CAD89 Posted December 30, 2012 Author Posted December 30, 2012 Solved the layer problem: (defun pad:ll () (setq la (cdr (assoc 2 (tblnext "Layer" T)))) (setq lal (list la)) (while (/= (setq la (cdr (assoc 2 (tblnext "Layer")))) nil) (setq lal (append lal (list la)) ) ) ) I think it works the same with the text styles! Still need help with the fonts though! Quote
Tharwat Posted December 30, 2012 Posted December 30, 2012 (defun _List (typ / lst) (while (setq e (tblnext typ (null e))) (setq lst (cons (cdr (assoc 2 e)) lst))) lst ) usage ... With Layers ... (_List "Layer") usage ... With Text Styles ... (_List "Style") 1 Quote
CAD89 Posted December 30, 2012 Author Posted December 30, 2012 Thank you for your help! Any idea about the fonts list? I would need something like in the text style dialog box! Is it possible? Quote
Tharwat Posted December 30, 2012 Posted December 30, 2012 Thank you for your help! You're welcome . Any idea about the fonts list? I would need something like in the text style dialog box! Is it possible? Do you mean to list all the fonts that are used in the text styles list ? Quote
CAD89 Posted December 30, 2012 Author Posted December 30, 2012 Yes! Is that in any way possible? Updated the layer code: (defun pad:ll () (setq la (cdr (assoc 2 (tblnext "Layer" T)))) (setq lal (list la)) (while (/= (setq la (cdr (assoc 2 (tblnext "Layer")))) nil) (setq lal (append lal (list la)) ) ) (if (= lal (list nil)) (setq lal (list (cdr (assoc 2 (tblnext "Layer" T))))) (setq lal (append lal (list "Use current" "Make new ..."))) ) ) ... for some reason the code gave me a nil list if there was only one layer so I updated and added two more items that I will need later on! Thank you for your time Tharwat! Quote
Tharwat Posted December 30, 2012 Posted December 30, 2012 Check this out ... (defun _List-Fonts (/ e lst) (while (setq e (tblnext "Style" (null e))) (setq lst (cons (cdr (assoc 3 e)) lst))) lst ) (_list-Fonts) Quote
CAD89 Posted December 30, 2012 Author Posted December 30, 2012 I'm sorry but the code you wrote will return a list of only the fonts that are currently set or assigned to existent text styles and not a font list of every font that AutoCAD has in it's fonts library! Quote
Tharwat Posted December 30, 2012 Posted December 30, 2012 I'm sorry but the code you wrote will return a list of only the fonts that are currently set or assigned to existent text styles and not a font list of every font that AutoCAD has in it's fonts library! That's why I asked you before as you can see below .. Do you mean to list all the fonts that are used in the text styles list ? Anyway here is a routine to list all your shx fonts from the FONTS folder but don't forget to change the path according to yours . (defun _List-Fonts nil (foreach shx (vl-directory-files "C:\\Program Files\\Autodesk\\AutoCAD 2013\\Fonts" "*.shx" 1) (print shx) ) ) Quote
Lee Mac Posted December 30, 2012 Posted December 30, 2012 Perhaps something like: ([color=BLUE]defun[/color] _getfontlist ( [color=BLUE]/[/color] _parsepaths ) ([color=BLUE]defun[/color] _parsepaths ( s [color=BLUE]/[/color] p ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] p ([color=BLUE]vl-string-position[/color] 59 s)) ([color=BLUE]vl-remove[/color] [color=MAROON]""[/color] ([color=BLUE]cons[/color] ([color=BLUE]substr[/color] s 1 p) (_parsepaths ([color=BLUE]substr[/color] s ([color=BLUE]+[/color] p 2))))) ([color=BLUE]list[/color] s) ) ) ([color=BLUE]vl-sort[/color] ([color=BLUE]apply[/color] '[color=BLUE]append[/color] ([color=BLUE]cons[/color] ([color=BLUE]vl-directory-files[/color] (LM:SpecialFolder [color=MAROON]"Fonts"[/color]) [color=MAROON]"*.ttf"[/color] 1) ([color=BLUE]mapcar[/color] ([color=BLUE]function[/color] ([color=BLUE]lambda[/color] ( p ) ([color=BLUE]vl-directory-files[/color] p [color=MAROON]"*.shx"[/color] 1)) ) (_parsepaths ([color=BLUE]getenv[/color] [color=MAROON]"ACAD"[/color])) ) ) ) '[color=BLUE]<[/color] ) ) [color=GREEN];; Special Folder - Lee Mac[/color] [color=GREEN];; Queries the WshSpecialFolders collection for the specified folder[/color] [color=GREEN];; Ref: http://msdn.microsoft.com/en-us/library/9x9e7edx%28v=vs.85%29.aspx[/color] ([color=BLUE]defun[/color] LM:SpecialFolder ( folder [color=BLUE]/[/color] res spf wsh ) ([color=BLUE]setq[/color] res ([color=BLUE]vl-catch-all-apply[/color] ([color=BLUE]function[/color] ([color=BLUE]lambda[/color] ( ) ([color=BLUE]setq[/color] wsh ([color=BLUE]vlax-get-or-create-object[/color] [color=MAROON]"wscript.shell"[/color]) spf ([color=BLUE]vlax-get-property[/color] wsh 'specialfolders) ) ([color=BLUE]vlax-invoke-method[/color] spf 'item folder) ) ) ) ) ([color=BLUE]if[/color] spf ([color=BLUE]vlax-release-object[/color] spf)) ([color=BLUE]if[/color] wsh ([color=BLUE]vlax-release-object[/color] wsh)) ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]vl-catch-all-error-p[/color] res)) res ) ) (untested code) 1 Quote
CAD89 Posted December 30, 2012 Author Posted December 30, 2012 Thank you for your time Tharwat and Lee Mac ... This was what I was looking for! Quote
Tharwat Posted December 31, 2012 Posted December 31, 2012 Thank you for your time Tharwat and Lee Mac ... This was what I was looking for! Happy to help . Quote
