I know this is probably a super easy fix, but I just don't know how to do it. I have a macro that works great in my toolbar and/or ribbon, but I want to make it a script so that I can put it in a program such as Multi-batch and use it on several drawings at one time. How do I convert a macro to a script? Basically what the macro currently does is pop my drawing into paperspace, zoom extents, turn off layers I don't need, and change the Ltscale and psltscale to be correct for printing. Any suggestions would be appreciated. Thanks so much. Here is the macro:
^C^C(setvar "pdmode" 0);_tilemode;0;zoom;extents;ltscale;0.5;-layer;f;*A-ANNO-ENGR,*A-SEAL-ASBESTOS,*A-SEAL-CIVIL,*A-SEAL-FIRE,*A-SEAL-ELEC,*A-SEAL-MECH,*A-SEAL-PLUMB,*A-SEAL-STRUCT;;
Edited by SLW210
Code Tags!!!
Start Windows Notepad.Copy your macro into it.
Remove the ^C^CRemove each semi-colon and replace with a hard return so that each entry between ; symbols is on its own line (or a blank line where you have double ;; symbols).
Save the file with an SCR
Now test it using SCRIPT command.
Thanks that worked perfectly.Now to throw it in the multibatch program to see if that program works the way I want
