tlawson Posted December 23, 2012 Posted December 23, 2012 I have a 3D solid with a hole through the center. I would like to select the edge of the hole and apply a fillet but I don't seem to be able to get it to work. The lines below are contained in my .SCR Notepad file. There is 2 blank lines at the end of the script. fillet radius 0.86603 0,6.48445669243112,13 When I run the script AutoCAD returns the information below. Command: scr SCRIPT Command: fillet Current settings: Mode = Trim, Radius = 0.87 Select first object or [undo/Polyline/Radius/Trim/Multiple]: radius Specify fillet radius <0.87>: 0.86603 Select first object or [undo/Polyline/Radius/Trim/Multiple]: 0,6.48445669243112,13 Enter BACKSPACE to interrupt script. Command: FILLET Current settings: Mode = Trim, Radius = 0.87 Select first object or [undo/Polyline/Radius/Trim/Multiple]: If I run the script line by line then it works so what am I doing wrong? Tony Quote
tlawson Posted December 23, 2012 Author Posted December 23, 2012 So I don't waste anyone's time I have now found the solution by replacing "FILLET" with "_.FILLET" I'm stiil not sure why this works but it works. Quote
tzframpton Posted December 24, 2012 Posted December 24, 2012 So I don't waste anyone's time I have now found the solution by replacing "FILLET" with "_.FILLET" I'm stiil not sure why this works but it works. R.K.McSwain has explain the differences in the "[COMMAND]" with "_.[COMMAND]" before but I have forgotten the exact explanation. It might still be up on his blog, CAD Panacea, if you're curious enough to search why. Maybe even a Google search? Just thought I'd share in case you're interested. Quote
tlawson Posted December 24, 2012 Author Posted December 24, 2012 I know that the underscore has something to do with different language packs but have never seen the period after the underscore. Quote
