hmsilva Posted December 26, 2012 Posted December 26, 2012 Just for testing copy and paste in the command line (vla-get-activedocument (vlax-get-acad-object)) tell me what you get Quote
hmsilva Posted December 26, 2012 Posted December 26, 2012 is not a problem with "activex", I do not see what is. Others lisps work well on that machine? Quote
BrianTFC Posted December 26, 2012 Author Posted December 26, 2012 yeah they all work just fine. that's whats got me stumped. Quote
hmsilva Posted December 26, 2012 Posted December 26, 2012 Me too... I google the error and found several errors like that, some caused by installation error,and solved by repairing or reinstalling, or by other error in Support File Search Path, solved placing the correct path. See if you can find any errors in the paths... Maybe someone who had the same error might help? Henrique Quote
BrianTFC Posted January 2, 2013 Author Posted January 2, 2013 hmsilva, Hope you had a great holiday and a Happy New Years eve. I never could figure out why i counldn't run it on an older verison of Autocad, but its okay i use 2012 on my main computer. i was wondering how i can i make the lisp rountine run until told to stop. i know it has to do with a "while" or some sort of loop. i not every good at finding the right place to put it in a routine i'm still learning. is it after the loop command? Brian Quote
Lee Mac Posted January 2, 2013 Posted January 2, 2013 Try the following quick program Brian: ([color=BLUE]defun[/color] c:psave ( [color=BLUE]/[/color] dfn dir doc dwg llp sel ssc sso tmp urp ) ([color=BLUE]setq[/color] doc ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color])) ssc ([color=BLUE]vla-get-selectionsets[/color] doc) dir ([color=BLUE]getvar[/color] 'dwgprefix) ) ([color=BLUE]if[/color] ([color=BLUE]vl-catch-all-error-p[/color] ([color=BLUE]setq[/color] sso ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vla-item[/color] ([color=BLUE]list[/color] ssc [color=MAROON]"wbset"[/color])))) ([color=BLUE]setq[/color] sso ([color=BLUE]vla-add[/color] ssc [color=MAROON]"wbset"[/color])) ([color=BLUE]vla-clear[/color] sso) ) ([color=BLUE]while[/color] ([color=BLUE]setq[/color] sel (LM:ssget [color=MAROON]"\nSelect Border: "[/color] '([color=MAROON]"_+.:E:S"[/color] ((0 . [color=MAROON]"INSERT,LWPOLYLINE"[/color]))))) ([color=BLUE]vla-getboundingbox[/color] ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]ssname[/color] sel 0)) 'llp 'urp) ([color=BLUE]vla-select[/color] sso [color=BLUE]acselectionsetwindow[/color] llp urp) ([color=BLUE]if[/color] ([color=BLUE]<[/color] 0 ([color=BLUE]vla-get-count[/color] sso)) ([color=BLUE]progn[/color] ([color=BLUE]vlax-for[/color] obj sso ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]=[/color] [color=MAROON]"AcDbText"[/color] ([color=BLUE]vla-get-objectname[/color] obj)) ([color=BLUE]wcmatch[/color] ([color=BLUE]vla-get-textstring[/color] obj) [color=MAROON]"@*"[/color]) ) ([color=BLUE]setq[/color] dwg ([color=BLUE]vla-get-textstring[/color] obj)) ) ) ([color=BLUE]if[/color] ([color=BLUE]findfile[/color] ([color=BLUE]setq[/color] dfn ([color=BLUE]strcat[/color] dir dwg [color=MAROON]".dwg"[/color]))) ([color=BLUE]progn[/color] ([color=BLUE]setq[/color] tmp 1) ([color=BLUE]while[/color] ([color=BLUE]findfile[/color] ([color=BLUE]setq[/color] dfn ([color=BLUE]strcat[/color] dir dwg [color=MAROON]"("[/color] ([color=BLUE]itoa[/color] ([color=BLUE]setq[/color] tmp ([color=BLUE]1+[/color] tmp))) [color=MAROON]").dwg"[/color])))) ) ) ([color=BLUE]vla-wblock[/color] doc dfn sso) ([color=BLUE]vla-clear[/color] sso) ) ) ) ([color=BLUE]vla-delete[/color] sso) ([color=BLUE]princ[/color]) ) [color=GREEN];; ssget - Lee Mac[/color] [color=GREEN];; A wrapper for the ssget function to permit the use of a custom selection prompt[/color] [color=GREEN];;[/color] [color=GREEN];; Arguments:[/color] [color=GREEN];; msg - selection prompt[/color] [color=GREEN];; params - list of ssget arguments[/color] ([color=BLUE]defun[/color] LM:ssget ( msg params [color=BLUE]/[/color] sel ) ([color=BLUE]princ[/color] msg) ([color=BLUE]setvar[/color] 'nomutt 1) ([color=BLUE]setq[/color] sel ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]ssget[/color] params)) ([color=BLUE]setvar[/color] 'nomutt 0) ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]vl-catch-all-error-p[/color] sel)) sel) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) Quote
hmsilva Posted January 2, 2013 Posted January 2, 2013 Brian, Happy New Year too (defun c:psave (/ ss mn mx sst) (vl-load-com) (while (setq ss (ssget "_:S:E" '((0 . "INSERT,LWPOLYLINE")))) (progn (vla-getboundingbox (vlax-ename->vla-object (ssname ss 0)) 'mn 'mx ) (setq sst (ssget "W" (trans (vlax-safearray->list mn) 0 1) (trans (vlax-safearray->list mx) 0 1) '((0 . "text") (1 . "~(*")) ) ) (if (= (findfile (strcat (getvar "dwgprefix") (cdr (assoc 1 (entget (ssname sst 0)))) ".dwg" ) ) nil ) (progn (command "-wblock" (strcat (getvar "dwgprefix") (cdr (assoc 1 (entget (ssname sst 0)))) ) " " "0" "WINDOW" (trans (vlax-safearray->list mn) 0 1) (trans (vlax-safearray->list mx) 0 1) "" ) (command "oops") ) ;; progn (alert (strcat "\nThe " (cdr (assoc 1 (entget (ssname sst 0)))) ".dwg already exists in the current directory!!!" ) ) ) ;; if ) ;; progn ) ;; while (princ) ) Henrique Quote
