What am I doing wrong?
I encountered the problem when I was test-rendering a scene where you are supposed to be able to look into nearby rooms through glass walls. But the glass reflected the surroundings like å mirror. In some tries i could bearly see some furniture in the other room, so the transperency isn't completely gone.
I use a solid glass material, at first i thought the material's reflection value was too high, but it was set on five, I tried to reduce it to 1, but the rendering came out just the same.
I have tried with different lighting options, but again... the same miserable result.
Any help would be very welcome! :)
Edited by Jawo
Is there a transparency setting by any chance? Or is it called opaqueness?
Unfortunatly I can't find any. The options are:
Color
Custom color
Reflectance
Refraction
Roughness
There is a Transparency option listed on the Appearance tab.
  • 1 month later...
I'm sorry for not replying right away!
But I found out it was a question of different material qualities. I
used some material that is obviously is made for being smoked,
and I did not get that, because its name was "glass clear03" or
something like it. I should have explored more with different
materials.
Help I thank you for! Gentlemen you are
- Jawo
