Chamfer between surfaces in RhinoParametrics
I don't succeed in creating a chamfer between two surfaces with the RhinoParametrics plugin. Does someone know how to do it ?
  • 2 weeks later...
The chamfer between surface command is not interpreted in RhinoParametrics.
You need to ask to their support to know if it's possible
  • 3 weeks later...
Chamfer are not implemented in RhinoPArametrics but you can use Rhino history and RhinoParametrics to use non interpreted feature.
Follow this video tutorial to know how to do:
I haven't test Rhino history with chamfer.
