RhinoParametrics formulas precisions
I have some problems in the RhinoParametrics plugin with the new formulas feature : there is an inaccurate result in formulas.
If I type 51/2 the result is 25 instead of 25.5 ...
Is there someone who could try to help me ?
Hi,
I had the same problem and found the solution with the RhinoParametrics help.
When you use division you need to write you number with a dot.
The help says:Attention to the division operator. RhinoParametrics make the difference between an integer division and a floatting division. If we wish the result to be a decimal value, it's necessary that one of the values is a decimal value.
Here an example : The integer division :21 / 2 = 10
The decimal division: 21 / 2.0 = 10.5
