eaglescout Posted November 29, 2012 Posted November 29, 2012 ok please help we were using an old version of autocad 2000. when inserting aerial photo into our drawing we have zero problems viewing the image or printing the image with enough quality to use as a submittal. but currently we have upgraded to autocad 2012 and opening these same drawing the image looks good but when printing the image is real pixelated, making the drawing unusable. the image prints like a digital camo pattern it is that bad pixelated. ive increased the rasterdpi, ive increased the dri in our pc3 print file. even tried multiple drivers. same problem happens when printing to dwg to pdf. please anyone have any suggestions. Quote
tonyj Posted November 29, 2012 Posted November 29, 2012 Are you printing from model space or paper space? Quote
hazardman Posted November 29, 2012 Posted November 29, 2012 how is the image attached?..with the image command or as an OLE?..if OLE, check options>plot and publish tab> at the OLE plot quality drop down choose either high or automatic... Quote
Murph_map Posted November 29, 2012 Posted November 29, 2012 Check the settings in the raster options "_mapioptions" for the dialog if you didn't already. Quote
