Catenary Posted November 28, 2012 Posted November 28, 2012 All my sources say I can create a perpendicular or tangent arc from the end of a line segment by holding down the left mouse button. The Direct Manipulation Tutorial even suggests the arc doesn't have to be perpendicular or tangent. Alas, I have spent far too long trying various permutations of click and hold with not even the slightest hint of an arc to show for it. What am I missing? Quote
JD Mather Posted November 29, 2012 Posted November 29, 2012 Click first point for line. Click second point for line. Click on second endpoint and drag the mouse like you were dragging a pencil in an arc. Tip #24 http://home.pct.edu/~jmather/SkillsUSA%20University.pdf Quote
Catenary Posted November 29, 2012 Author Posted November 29, 2012 J. D. Mather, I appreciate your prompt suggestion. I have spent at least an hour and a half looking at various options and default settings after trying unsuccessfully and frustratingly to do this seemingly simple and basic maneuver. With the line command active in Sketch, I left-click and release anywhere in the sketch plane to create the start of a line (A). I then move the mouse, left-click and release on a second point (B) to create a line segment. So far so good. Case 1) I move the cursor with no button action whatsoever, creating another, connected line segment. Case 2) I move the cursor without releasing the button after pausing at point B This moves point B. Both Case 1 and Case 2 produce the expected result. Case 3) Expecting to draw an arc, after releasing the left button at B, I left-click and hold but the result is another straight line segment, no matter how fancy a gyration I impart to the mouse. I have tried double clicking, double click and hold, exiting and re-entering the line commmand and several permutations of the above, all without success. I have played with relative and absolute coordinates to no avail. I have opened a new sketch plane with the same result. At this point I'm going to bed before I get too discouraged. Quote
JD Mather Posted November 29, 2012 Posted November 29, 2012 I have played with relative and absolute coordinates to no avail.. Are we talking about Autodesk Inventor (I have never heard of using relative or absolute coodinates in Inventor - post screen shot). Also - constraint persistence must be turned on (default setting - so it should be on unless you turned it off) and Constraint Options - Coincident must be turned on (default setting - so it must be on unless you turned it off). Check these two settings. Attach your ipt file here. Quote
Catenary Posted November 29, 2012 Author Posted November 29, 2012 Yes, this is Inventor 2100. After checking the environment variables you suggested, click-hold now produces an arc as it's supposed to. Thank you. I'll play around to try to make it non-perpendicular or tangent, as the tutorial (Direct Manipulation - Sliding-pin Hangar.ipt) suggests I can. As to the absolute/relative coordinates, when the line command is active, right-click on the sketch plane>Coordinate Types>Absolute, Relative, Polar, Cartesian. The Absolute is greyed out, but I thought that when I first ventured there it was an option. Adding the screen shot you requested makes the message exceed the 15,000 character limit: is there another way to get it to you? Quote
JD Mather Posted November 29, 2012 Posted November 29, 2012 As to the absolute/relative coordinates, when the line command is active, right-click on the sketch ..... Hmmm, learned something new today. Don't know how I will ever use that in Inventor, but something new to me. I think there are a total of 8 different ways you can drag out the arc. It takes a bit of practice, but becomes automatic after a while. Quote
