I'd like to share something I just discovered. It may be old news to many of you.
Select a dimension. Select the text grip. Right click. You'll get a menu for doing some neat things with the text, such as moving it independently, resetting it, and centering it vertically. You can even rotate the dimension.
I was trying to move some dimension text because the plan doesn't line up with the UCS. Either the text was upside down (reading left to right) or on the wrong side of the line (reading right to left). This beats exploding the dimension!
Just hover over the grip, right clicking brings up other choices.
