stevo99 Posted November 21, 2012 Posted November 21, 2012 Hi There, I have a dynamic steel section block with a btable to choose which size member you want. What I want to know is there any way I can add a field to the block that shows the selected size so that I don't need to add a separate call up. The field would be linked to the block so if I was to change the size of the member, the field would update and no risk of someone not updating the call up by mistake. Thanks Quote
Dadgad Posted November 22, 2012 Posted November 22, 2012 You should visit Lee Mac's site, he has lots of great lisps there, look around, http://www.lee-mac.com/dinfo.html as he likely has a tool to help you. Thanks Lee! You could also do this using the DATAEXTRACTION functionality, to create a block driven display element on your drawing. Quote
KiLLiNG-TiME Posted November 26, 2012 Posted November 26, 2012 You may also want to check out this thread http://www.cadtutor.net/forum/showthread.php?74868-Display-block-scale p.s. lee mac is a Quote
