does anyone have a special linetype they use to show haybales? I work for a civil design company and they use a really heavy dashed line to represent them. My old company had a lintype but i do not have access to those anymore.
what did your old company's linetype look like?
its tough to describe but ill try. it was basically the top view of a haybale with two stakes in it only much smaller and less detailed but it was a rectangle and centered vertically were two dots to represent the stakes. see the attachement i drew it quick in paint
ya that would definitely work, i will most likely edit it to take out the lines in between to make it appear the haybales are right next to each other.
dont know if you've ever used the MKLTYPE command...under Express>Tools
just drew the hay bale and converted to shape...then made the linetype
