RhinoParametricss plugin
Do you know the RhinoParametrics plugins?
I use it since some months, and it's really a good plugin to create different design of a same project.
Now I search to use the surface by network command, but I encounter some problems.
When I create a surface by network curve RhinoParametrics display a dialog asking me if I want create a link objet.
If I click yes or no, this surface is not parametric.
How can I made this surface parametric?
Surface by network is not implemented in RhinoParametrics.
But you can combine Rhino history and RhinoParametrics "Link" object to have a parametric surface.
I advise you to active the Rhino history before launch the _NetworkSrf command and click yes on the dialog asking you to create a link obejct.
Use of Rhino history and link object can allow you to use non implemented method in RhinoParametrics
Thanks for this answer.
It's really confortable to have the ability to use all non interpreted rhino commands with this feature.
Good job.
