How do you convert AutoCAD Architecture 2013 files back to 2012?
Could someone tell me how you convert AutoCADArchitecture 2013 files back to 2012 if you don't have 2013? I have tried usingTrueview 2013 but I still have object which are causing a problem. When I tryto use some of the basic AutoCAD commands such as 'fillet' I get the followingmessage ' Command not allowed because drawing contains objects from a newerversion of this application.'
It needs to be EXPORTED from the 2013 version. What version did you convert to from DWG TrueView?
I converted a 2013 file using Trueview 2013 to 2010.
I did get the other party to export to 2010 and it worked fine.
I can't see the point of having a convert option in Trueview if it doesn't allow full compatability.
