vkmaynard Posted October 31, 2012 Posted October 31, 2012 When exporting to an IGES format the threads are missing. Why? Thanks, Victor Quote
JD Mather Posted October 31, 2012 Posted October 31, 2012 Cosmetic threads or modeled threads? My guess is cosmetic (picture texture that sort of looks like threads). Zoom in and see if you have real threads (v-notch geometry). Quote
vkmaynard Posted October 31, 2012 Author Posted October 31, 2012 The threads were made by drilling a hole in a solid and specifying the thread type. Victor Quote
Bishop Posted October 31, 2012 Posted October 31, 2012 Those threads are just an image map that Inventor applies to give the appearance of threads. They're not really there - it's just a smooth face of the appropriate diameter, as far as exporting goes. If you take a look in the Autodesk exchange, though, you can download an app - made by Autodesk - that will convert your threaded hole features into actual modeled threads. You can export those as actual geometry. Quote
Bishop Posted November 1, 2012 Posted November 1, 2012 This should have all the info you'll need. Quote
vkmaynard Posted November 1, 2012 Author Posted November 1, 2012 Thanks. Found it, installed it, does not show on the ribbon. Quote
Bishop Posted November 1, 2012 Posted November 1, 2012 Part modeling environment, tools tab, right side. Quote
vkmaynard Posted November 1, 2012 Author Posted November 1, 2012 Problem solved thanks to PhilippeLeefsma Senior Developer Consultant. He sent a link to the correct version for 2011. Note: This tool converts a Thread Festure not a Hole Feature using a thread. Thanks Philippe!! Quote
vkmaynard Posted November 1, 2012 Author Posted November 1, 2012 One last problem. I cannot use this on o.125" plate with any thread size. I get an error message --------------------------- Modelization Error --------------------------- Failed to create CoilFeature... Try with a bigger Pitch Offset value --------------------------- OK Cancel --------------------------- Quote
Bishop Posted November 1, 2012 Posted November 1, 2012 Attach your part here, we'll have a look at it. Quote
vkmaynard Posted November 1, 2012 Author Posted November 1, 2012 Done. I was able to use the tool on a part with only 0.100" thickness. Thanks, Victor Emergency Release Link 1.iptFetching info... Quote
Bishop Posted November 1, 2012 Posted November 1, 2012 Huh. That's ... interesting. I think it's got something to do with the sketch that's getting used as a template for the coil feature, but I'm not positive. Quote
vkmaynard Posted November 2, 2012 Author Posted November 2, 2012 I was just told that the plugin does not work with sheet metal parts. Does not make sense. Quote
Bishop Posted November 2, 2012 Posted November 2, 2012 Looks to be the case. As soon as I turned it back into a standard part, Thread Modeler worked out just fine. That part though, it doesn't really need to use any of Inventor's sheet metal tools, so there's no need to make it as a sheet metal part. Quote
vkmaynard Posted November 2, 2012 Author Posted November 2, 2012 Agree on that part. I do have a sheet metal part that requires bening that has holes. Does not make sense. Quote
JD Mather Posted November 2, 2012 Posted November 2, 2012 You can always convert a standard part to sheet metal (or the other way around). Quote
Bishop Posted November 2, 2012 Posted November 2, 2012 Once you've used Thread Modeler you can't convert back to sheet metal, JD. Features are incompatible, unfortunately. Although ... this brings up another point: when you convert to .IGS, you're going to be losing all the tooling stuff that Inventor builds into the sheet metal parts. Your flat pattern, bend angles, etc., aren't going to come through. You'll just get a model, so you're really not giving away anything to just make the sheet metal part, then convert to a standard part and do the threads afterwards. Quote
vkmaynard Posted November 2, 2012 Author Posted November 2, 2012 Thanks. I made a backup then converted and threaded. 5 years later ready to send the design for production pricing. Quote
