Sarah_H Posted October 24, 2012 Posted October 24, 2012 (edited) When the modify dimensions box is open, the 'roundoff' menu gives me 1/16", 1/8" etc, even when DECIMAL is selected as the unit format. This wasn't happening earlier, not sure what's going on. [in fact in a solved problem from earlier, a colleague found a drawing that had units set to millimeters, had its insertion scale set to inches! Different computer, so not related] Any suggestions welcome! Edited October 24, 2012 by Sarah_H Quote
MSasu Posted October 24, 2012 Posted October 24, 2012 Please make sure that drawing's units are also set to Decimal (see UNITS command). Quote
Sarah_H Posted October 24, 2012 Author Posted October 24, 2012 That's the badger, solved the problem! Stupidly, it solved my colleague's earlier problem, I have no idea why I didn't think it would work with another, similar issue! Thanks very much for your reply Quote
MSasu Posted October 24, 2012 Posted October 24, 2012 Glad to hear that your issue is now gone. You're entirely welcome! Quote
