robierzo Posted October 19, 2012 Share Posted October 19, 2012 Hello. I need to know if a point is inside or outside a polyline. Thank you.Punto dentro o fuera de polilinea.dwg Quote Link to comment Share on other sites More sharing options...
MSasu Posted October 19, 2012 Share Posted October 19, 2012 I believe you are talking of a closed polyline. One solution is to try to call the BOUNDARY command using that point and check the last entity in drawing. If there was a new polyline added, then you picked inside the base polyline. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted October 19, 2012 Share Posted October 19, 2012 Try this .... (defun c:Test (/ p1 p2 gr) ;;;;; Tharwat 28. June. 2012 ;;;;; (if (and (setq p1 (getpoint "\n Specify point :")) (setq p2 (getcorner p1 "\n Corner :")) ) (while (eq (car (setq gr (grread t 15 1))) 5) (redraw) (foreach n '((0.5 0.5 0.0) (-0.5 0.5 0.0)(-0.5 -0.5 0.0)(0.5 -0.5 0.0)) (grdraw (cadr gr) (mapcar '+ (mapcar (function (lambda (x) (* x (/ (getvar "VIEWSIZE") 25.)))) (trans n 1 0)) (cadr gr) ) 1 0 ) ) (if (and (< (car p1) (car (cadr gr))) (> (car p2) (car (cadr gr))) (> (cadr p1) (cadr (cadr gr))) (< (cadr p2) (cadr (cadr gr))) ) (princ "\n inside ...... ") (princ "\n outside ..... ") ) ) ) (redraw) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
MSasu Posted October 19, 2012 Share Posted October 19, 2012 You may adapt this for your code: (defun c:TestPick( / refEntity thePoint ) (setq refEntity (entlast)) (setq thePoint (getpoint "\nPick a point:")) (command "_BOUNDARY" thePoint "") (if (equal refEntity (entlast)) (prompt "\nPicked outside!") (progn (prompt "\nPicked inside!") (entdel (entlast)) ) ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
robierzo Posted October 19, 2012 Author Share Posted October 19, 2012 Thank you both. It's great. thanks. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 19, 2012 Share Posted October 19, 2012 Here is my method: [color=GREEN];; Point Inside-p - Lee Mac[/color] [color=GREEN];; Utilises a ray-casting algorithm to determine whether a[/color] [color=GREEN];; given point (WCS) resides within a supplied object.[/color] ([color=BLUE]defun[/color] LM:PointInside-p ( pt obj [color=BLUE]/[/color] lst ray ) ([color=BLUE]setq[/color] lst ([color=BLUE]vlax-invoke[/color] ([color=BLUE]setq[/color] ray ([color=BLUE]vla-addray[/color] ([color=BLUE]vla-objectidtoobject[/color] ([color=BLUE]vla-get-document[/color] obj) ([color=BLUE]vla-get-ownerid[/color] obj)) ([color=BLUE]vlax-3D-point[/color] pt) ([color=BLUE]vlax-3D-point[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] pt '(1.0 0.0 0.0))) ) ) 'intersectwith obj [color=BLUE]acextendnone[/color] ) ) ([color=BLUE]vla-delete[/color] ray) ([color=BLUE]=[/color] 1 ([color=BLUE]logand[/color] 1 ([color=BLUE]length[/color] lst))) ) To test: ([color=BLUE]defun[/color] c:test ( [color=BLUE]/[/color] ent obj pnt ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] ent ([color=BLUE]car[/color] ([color=BLUE]entsel[/color] [color=MAROON]"\nSelect Polyline: "[/color]))) ([color=BLUE]if[/color] ([color=BLUE]vlax-method-applicable-p[/color] ([color=BLUE]setq[/color] obj ([color=BLUE]vlax-ename->vla-object[/color] ent)) 'intersectwith) ([color=BLUE]while[/color] ([color=BLUE]setq[/color] pnt ([color=BLUE]getpoint[/color] [color=MAROON]"\nPick Point: "[/color])) ([color=BLUE]if[/color] (LM:PointInside-p ([color=BLUE]trans[/color] pnt 1 0) obj) ([color=BLUE]alert[/color] [color=MAROON]"Point is INSIDE"[/color]) ([color=BLUE]alert[/color] [color=MAROON]"Point is OUTSIDE"[/color]) ) ) ([color=BLUE]princ[/color] [color=MAROON]"\nInvalid Object selected."[/color]) ) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) More rigorous testing may be required to account for the case in which the projected ray is parallel to the intersecting edge. But the above will suffice for the majority of general applications. 1 Quote Link to comment Share on other sites More sharing options...
pBe Posted October 20, 2012 Share Posted October 20, 2012 Here is my method: [color=GREEN];; Point Inside-p - Lee Mac[/color] [color=GREEN];; Utilises a ray-casting algorithm to determine whether a[/color] [color=GREEN];; given point (WCS) resides within a supplied object.[/color] More rigorous testing may be required to account for the case in which the projected ray is parallel to the intersecting edge. But the above will suffice for the majority of general applications. I like it Thank you for sharing. Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted October 20, 2012 Share Posted October 20, 2012 I believe I've already answered to this topic and it was you robierzo... http://www.cadtutor.net/forum/showthread.php?72815-Point-inside-or-outside-of-another-entity M.R. Quote Link to comment Share on other sites More sharing options...
robierzo Posted October 20, 2012 Author Share Posted October 20, 2012 Lee, It's great. Too complicated for me. Thanks for sharing, Tharwat, MSasu, and Lee Mac. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted October 20, 2012 Share Posted October 20, 2012 Thanks for sharing, Tharwat. You're welcome Quote Link to comment Share on other sites More sharing options...
robierzo Posted October 20, 2012 Author Share Posted October 20, 2012 Uffff. Hello Marko. Admittedly. I've searched but have not found it. I apologize. Now we have four methods. Apologies. Thanks. The blood not watered me well the brain. :D. Thanks Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 20, 2012 Share Posted October 20, 2012 I like it Thank you for sharing. You're most welcome Quote Link to comment Share on other sites More sharing options...
