clarkey1987 Posted October 17, 2012 Posted October 17, 2012 Hi all am new to this site so please bare with me i am currently having a problem which (looks like) i have a background mask that will not delete even tho there isn't any text there. i cant select this or delete it. that's a print screen of one of the areas that's effected if someone could help me with this it will be much appreciated thanks in advance Andy Quote
ReMark Posted October 17, 2012 Posted October 17, 2012 Could it have anything to do with the setting of the system variable FRAME? Quote
SLW210 Posted October 17, 2012 Posted October 17, 2012 Are you sure they are wipeouts and that someone hasn't just trimmed the lines? Quote
CyberAngel Posted October 17, 2012 Posted October 17, 2012 Use the command IMGFRAME. That will toggle the visibility of the edges of the wipeouts. You can then delete the wipeouts. Quote
RobDraw Posted October 17, 2012 Posted October 17, 2012 CyberAngel said: Use the command IMGFRAME. That will toggle the visibility of the edges of the wipeouts. You can then delete the wipeouts. Unknown command. The correct one, IMAGEFRAME, does not control wipeout frames. Quote
ReMark Posted October 17, 2012 Posted October 17, 2012 I take it that all "frames" are not controlled by one command? I don't use wipeouts and seldom (counts on one hand) use image frame thus the reason for my question. Quote
Andy Clarke Posted October 17, 2012 Posted October 17, 2012 Thanks for the quick responses. the wipeout command suggested by RobDraw worked perfectly p.s Having problems with my account so had to open another to see the answers thanks again Quote
CyberAngel Posted October 17, 2012 Posted October 17, 2012 ReMark said: I take it that all "frames" are not controlled by one command? I don't use wipeouts and seldom (counts on one hand) use image frame thus the reason for my question. At one time I believe there was only one type of image, so there was only one command to toggle the frames. Now you can control frame visibility and plotting for images, PDFs, DGNs, DWFs, and who knows what else. I've tried wipeouts. So far there's always been a better solution. Sorry, RobDraw, didn't notice the wipeout in your post. I bow to the superior ninja. Quote
