afrazawan Posted October 13, 2012 Posted October 13, 2012 I have a problem when i draw Arc Dim. its placing not correct way and also giving once line with his center point plz check below images and help me for this issue Quote
Dadgad Posted October 13, 2012 Posted October 13, 2012 (edited) I believe that what you are describing is a RADIUS DIMENSION, not an ARC DIMENSION. It is quite simple to reposition the text to any of the various positions shown in the image. Do any of these look something like what you are after? The examples on the left and center arcs are all ARC DIMENSIONS. Those on the right hand arc are RADIUS DIMENSIONS. Edited October 14, 2012 by Dadgad Quote
afrazawan Posted October 14, 2012 Author Posted October 14, 2012 friend i know this if u check your image 1 from right side if i draw dim. it ll show one line upto center of arc so how can i set this Quote
Dadgad Posted October 14, 2012 Posted October 14, 2012 (edited) By selecting the dimension first, then hover over the TEXT grip and select MOVE TEXT ONLY from the drop down hover menu. Then you can move it around to different locations until it displays as you want. Edited October 14, 2012 by Dadgad Quote
