viewbase command help!
Yes, I am aware of the Export Layout to Model feature. I could see where it would be advantageous to use but I haven't done so yet.
  • Replies 37
  • ReMark
    16
  • stenews
    11
  • Dadgad
    11
Posted Images
Like a moth drawn to the flame I could not resist going back and taking another look.
I went into model space and created a rectangle off one corner of the building. I used PressPull on it to give it some height. I went into Layout2 and started the View Base command from scratch. I asked for a Top view and specified that I wanted it to be Shaded with visible lines and that is exactly what I got.
The object circled in red is my extruded rectangle.
Yes, the view in the lower right is off but that wasn't the point of this exercise.
Weird, I didn't try on a new layout tab. Well done. :beer:
His drawing was set for 1st Projection which is why the view seems odd to us yankees.
It is good to remember that you can change that on the LAYOUT tab, without using the ribbon.
I don't know if it was the new layout or the new object that made the difference. I would have to test that to be sure.
I tried previously just adding a new 3D Solid to modelspace, but the viewbase image was the same, no shading.
This is freaking me out. I attempted to reproduce what I just did and couldn't. Now I'm back to the unshaded view even with a new layout and a new 3D solid. Gadz!
Anomaly, time to let it be and move on.
I don't get it either, but hey :beer:
hi guys...it's me stenews sorry but I switched on my PC right on.
I read all your posts but I still not understand what's the problem...
I'm quoting ReMark now
...we are missing some system variable...
may be he is right, but which one?
That was just conjecture on my part. Can say one way or the other at the moment.
the only way that I know is to copy and past all the drawing in a new fresh template...magically the viewbase hidden option starts back to work.
if you try to move the viewbase you'll see the shading comes up after you release it it stops again it's like over layered to samething...
Maybe it has something to do with how you created the drawing in the first place.
may be...but I can't understand it's a very simple one and not every times it happens, sometime every goes right and sometime one layout works and another one not
Other than your technique I can't think of a reason why it works in one drawing and not in another.
AutoCAD 2012. You install the service pack(s)?
no I have loaded 2013...any way I'm more than thank to you for your help
don't waste your time any more with that...I'm sure it's something like a bug
Well before you go any further download and install Service Pack 1 for 2013. Make sure you select the right version (32-bit vs. 64-bit).
which is very last version of the Service Pack 1 for 2013? and how can I check it out?
Version 1.1 I believe. The first version has some bugs and was withdrawn. Check it out? The only way I know is to look at the ReadMe.txt file. It will tell you want problems it addresses. I see no reason why you should not install the service pack.
