I have been working with AutoCAD on Windows for a couple of months, and right now, when I switched to Mac, it started to name the constraints, and when I go to properties and delete the name, nothing happens. How can I delete the name?
AutoCAD for MAC does not have Dynamic Block editing capabilities.
Dynamic blocks created in Windows can be inserted and used on a Mac, but they cannot be modified.
If you are dealing with Parametrics there is on the Parametric Tab on the ribbon a button to toggle on and off the dimensioning. By changing the parametric dimensions to annotational dimensions they will display as normal dimensions.
