tzframpton Posted May 8, 2016 Posted May 8, 2016 chrisdarmanin said: modelling in autocad is cumbersome, i'm much faster in sketchup. i never tried rendering in autocad, i assuming its also cumbersomeI see. From your post it sounded like AutoCAD was your main modeling application and looking to find a better rendering app. halam said: Can't believe you made the guitar body so smooth looking in AutoCAD 3D, wauw man!I model stuff in AutoCAD but it all for technical use. No good experiences with rendering like this. It is hard and clumbersome indeed AutoCAD seems not so developed for this work. Need for a 'hybrid sollution' seems logical to me... Thanks Halam. Here is the project in full: http://www.cadtutor.net/forum/showthread.php?71752-WIP-Modeling-My-Fender-Squier-Stratocaster I learned a lot, mainly that AutoCAD is not the best tool to do such a project. But I am very happy with the final output. Shows that AutoCAD is still plenty capable. Quote
chrisdarmanin Posted May 9, 2016 Posted May 9, 2016 yes you are right, i used to swear by autoCAD, then i came across sketchup and started using it due to a feature autocad didnt have - shadows. then as i learned it more i loved it more. still nothing will replace autocad 2d Quote
SLW210 Posted May 9, 2016 Posted May 9, 2016 You might give Luxrender a look, works with Sketchup. Quote
tzframpton Posted May 9, 2016 Posted May 9, 2016 chrisdarmanin said: yes you are right, i used to swear by autoCAD, then i came across sketchup and started using it due to a feature autocad didnt have - shadows. then as i learned it more i loved it more. still nothing will replace autocad 2dIf you are in the architectural design industry then you may look at Revit LT. It's as easy as Sketchup (if not easier in some areas) on a fundamental level, but is much more powerful overall, plus has in-application shadows/lighting in the same way Sketchup does. Quote
