Hi,
the lisp, anticipated with two images here and here, aligns between two curves the hatch elements and creates a block containing the lines of the new geometry.
The original shape of the hatch shall be a rectangle, an isosceles triangle or an isosceles trapezoid.
In case of large hatches is recommended to divide it into portions, any case it is better to try with small hatches to verify the time required for processing, in according to PC performances, too.
Not all hatches are suitable for processing.
I hope it works well and there are no problems.
AlignH.lspFetching info...
  • Like 4
  • Thanks 2
haven't tried it yet but it sure looks good!
thanks for sharing!
That is really great GP, :beer:
thanks very much.
Awesome!!! :thumbsup:
I will get a chance to give it a play next week, hopefully.
Thanks to all.
I am happy that like it. :)
I am yet to study the method you have implemented, but given the demonstrations I must say the program looks rather impressive!
Guest kruuger
hello GP_
this is really cool lisp!!! i start using them but fail with one pattern. Please see attached file
is it possible to make a short description how do you calculate all these points? any source where i can read about this?
one suggestion. maybe replace all these popups with while loop?
thanks
kruuger
sample.dwgFetching info...
Edited by kruuger
That a really great tool! Congratulations!
If you don't mind, I’d make a suggestion; why don't ask the user to select only the target curves and the pattern (either as name or by acquiring from existing hatch) and create automatically the temporary reference hatch for your calculation based of length of those target curves?
@Lee - kruuger - Mircea
@ kruuger
First case.
I already said that not all hatches are suitable for processing.
Are adapted the individual lines (start/end point), you will get better results with short lines or transverse (if long).
Second case.
Attention to the selection point.
@Mircea
It 'a good idea, but it would only be used with method 3 (offset), which can be traced to a rectangular shape.
I also found the system to use a origin shape not rectangle, triangle or trapezoid (two lines randomly), but the computation time is excessive.
@SEANT
You are my muse.
@Gu_xl
Perfect.
The problem was on longitudinal long lines.
You have brilliantly solved.
Marvelous!
I played with it a bit. It appears not to like polyline objects. I used the rectangle command to draw my source hatch, and AlignH tells me that it is an "Invalid Object" If I draw the same hatch inside a rectangle made of lines, no problem. Likewise if I explode the rectangle before running AlignH.
Very cool - I don't draw many hatches, but I put this in my LISP folder.
Glen
  GP_ said:
@SEANT
You are my muse.
Thanks. I appreciate the comment.
With continued effort from the lot of us, perhaps AutoCAD will shed its rectilinear reputation. 8)
  • 7 years later...
Any idea why this isn't working anymore in AutoCAD 2019?
