waders Posted October 9, 2012 Posted October 9, 2012 Okay this seems like a simple one. How would I join these 2 commands so it doesn't matter if the line is a line or pline. Thanks [size=3][font=Calibri](defun c:heal2 (/ block ll ur p1 p2)[/font][/size] [size=3][font=Calibri] (vl-load-com)[/font][/size] [size=3][font=Calibri] (setq block (car (entsel "\nSelect Block:")))[/font][/size] [size=3][font=Calibri] (vla-getboundingbox (vlax-ename->vla-object block) 'll 'ur)[/font][/size] [size=3][font=Calibri] (command "_.erase" block "")[/font][/size] [size=3][font=Calibri] (command[/font][/size] [size=3][font=Calibri] "_.pedit"[/font][/size] [size=3][font=Calibri] "_m"[/font][/size] [size=3][font=Calibri] (ssget "C"[/font][/size] [size=3][font=Calibri] (setq p1 (vlax-safearray->list ll))[/font][/size] [size=3][font=Calibri] (setq p2 (vlax-safearray->list ur)))[/font][/size] [size=3][font=Calibri] ""[/font][/size] [size=3][font=Calibri] "_join" "_Joint" "_Both"[/font][/size] [size=3][font=Calibri] (distance p1 p2)[/font][/size] [size=3][font=Calibri] "")[/font][/size] [size=3][font=Calibri] (princ)[/font][/size] [size=3][font=Calibri] )[/font][/size] [size=3][font=Calibri](defun c:HEAL (/ block ll ur objecttojoin)[/font][/size] [size=3][font=Calibri] (vl-load-com)[/font][/size] [size=3][font=Calibri] (setq block (car (entsel "\nSelect Block:")))[/font][/size] [size=3][font=Calibri] (vla-getboundingbox (vlax-ename->vla-object block) 'll 'ur)[/font][/size] [size=3][font=Calibri] (command "_.erase" block "")[/font][/size] [size=3][font=Calibri] (setq objecttojoin[/font][/size] [size=3][font=Calibri] (ssget "C"[/font][/size] [size=3][font=Calibri] (vlax-safearray->list ll)[/font][/size] [size=3][font=Calibri] (vlax-safearray->list ur)))[/font][/size] [size=3][font=Calibri] (command[/font][/size] [size=3][font=Calibri] "_.join"[/font][/size] [size=3][font=Calibri] (ssname objecttojoin 0)[/font][/size] [size=3][font=Calibri] (ssname objecttojoin 1)[/font][/size] [size=3][font=Calibri] "")[/font][/size] [size=3][font=Calibri] )[/font][/size] Quote
pBe Posted October 10, 2012 Posted October 10, 2012 If you don't mind converting the lines to plines , you can use heal2 for both if you set peditaccept to 1 (defun c:heal2 (/ block pea ll ur p1 p2) (vl-load-com) [color="blue"] (setq pea (getvar 'Peditaccept)) (setvar 'PeditAccept 1)[/color] (setq block (car (entsel "\nSelect Block:"))) (vla-getboundingbox (vlax-ename->vla-object block) 'll 'ur) (command "_.erase" block "") (command "_.pedit" "_m" (ssget "C" (setq p1 (vlax-safearray->list ll)) (setq p2 (vlax-safearray->list ur))) "" "_join" "_Joint" "_Both" (distance p1 p2) "") [b][color="blue"] (setvar 'PeditAccept pea)[/color][/b] (princ) ) Quote
waders Posted October 10, 2012 Author Posted October 10, 2012 First of all thanks pBe for looking at this. If I had my choice I would like to convert plines into lines the join. But shouldn't I be able to add a: (cond ((= $ent2 line)(c:heal)) ((= $ent2 lwpolyline)(c:heal2)) ) $ent2 would be either line or lwpolyline pending which on is picked. Quote
pBe Posted October 12, 2012 Posted October 12, 2012 First of all thanks pBe for looking at this.If I had my choice I would like to convert plines into lines the join. Its either you explode the selection to turn it to lines then join or use heal2 then explode. But shouldn't I be able to add a: (cond ((= $ent2 line)(c:heal)) ((= $ent2 lwpolyline)(c:heal2)) ) $ent2 would be either line or lwpolyline pending which on is picked. (defun c:heald (/ pea block ll ur objs p1 p2) (vl-load-com) (setq pea (getvar 'Peditaccept)) (setvar 'PeditAccept 1) (setq block (car (entsel "\nSelect Block:"))) (vla-getboundingbox (vlax-ename->vla-object block) 'll 'ur) (command "_.erase" block "") [color="blue"][b] (setq objs[/b][/color] (ssget "C" (setq p1 (vlax-safearray->list ll)) (setq p2 (vlax-safearray->list ur)))) (if [b][color="blue"](eq (cdr (assoc 0 (entget (ssname objs 0)))) "LWPOLYLINE")[/color][/b] (command "_.pedit" "_m" [b][color="blue"]objs[/color][/b] "" "_join" "_Joint" "_Both" (distance p1 p2) "") (command "_.join" (ssname [color="blue"][b]objs[/b][/color] 0) (ssname [b][color="blue"]objs [/color][/b]1) "") ) (setvar 'PeditAccept pea) (princ) ) Quote
waders Posted October 12, 2012 Author Posted October 12, 2012 Thank you pBe. That works great. I see how you did it, but know I just need to figure out how you came up with it. I'm going to see if I can figure out how to filter out to only select blocks. If I do I'll repost. Thanks again for your help. Quote
pBe Posted October 12, 2012 Posted October 12, 2012 Thank you pBe. That works great. I see how you did it, but know I just need to figure out how you came up with it. Good for you, hope you'll learn from it. It is your code after all. I'm going to see if I can figure out how to filter out to only select blocks. If you mean multiple selection in one-go. Yes, it can be done. Pretty sure you'll figure it out on your own. keep us posted Cheers Quote
waders Posted October 18, 2012 Author Posted October 18, 2012 Okay I got so I can select only a block. But if I select more then one block it only works on one an ignore's the others. How would I make it run for each item in the selection set? Thanks (defun c:ee (/ pea $blk block ll ur objs p1 p2) (vl-load-com) (setq pea (getvar 'Peditaccept)) (setvar 'PeditAccept 1) (setq $blk (ssget '((0 . "insert")))) (setq block (ssname $blk 0)) (vla-getboundingbox (vlax-ename->vla-object block) 'll 'ur) (command "_.erase" block "") (setq objs (ssget "C" (setq p1 (vlax-safearray->list ll)) (setq p2 (vlax-safearray->list ur)) ) ) (if (eq (cdr (assoc 0 (entget (ssname objs 0)))) "LWPOLYLINE") (command "_.pedit" "_m" objs "" "_join" "_Joint" "_Both" (distance p1 p2) "" ) (command "_.join" (ssname objs 0) (ssname objs 1) "") ) (setvar 'PeditAccept pea) (princ) ) Quote
pBe Posted October 18, 2012 Posted October 18, 2012 (edited) lets try something (defun c:hint () (if (setq ss (ssget '((0 . "INSERT")))) (repeat (setq i (sslength ss)) (setq pt (cdr (assoc 10 (entget (setq e (ssname ss (setq i (1- i)))) )))) (command "_rotate" e "" "_non" pt "180") ) )(princ) ) Scroll down when you're ready ||| ||| ||| \ / \/ (defun c:ee (/ pea $blk block i ll ur objs p1 p2) (vl-load-com) (setq pea (getvar 'Peditaccept)) (setvar 'PeditAccept 1) [color="blue"](if [/color](setq $blk (ssget '((0 . "insert")))) [color="blue"] (repeat (setq i (sslength $blk)) (setq e (ssname $blk (setq i (1- i))))[/color] (vla-getboundingbox (vlax-ename->vla-object e) 'll 'ur) [color="blue"](entdel e)[/color] (setq objs (ssget "C" (setq p1 (vlax-safearray->list ll)) (setq p2 (vlax-safearray->list ur)) ) ) (if (eq (cdr (assoc 0 (entget (ssname objs 0)))) "LWPOLYLINE") (command "_.pedit" "_m" objs "" "_join" "_Joint" "_Both" (distance p1 p2) "" ) (command "_.join" (ssname objs 0) (ssname objs 1) "") [color="blue"]) ) (princ "\nNo Blocks Selected") )[/color] (setvar 'PeditAccept pea) (princ) ) See if you can use that as reference. This is CAD Tutor after all Edited October 18, 2012 by pBe Quote
waders Posted October 18, 2012 Author Posted October 18, 2012 Hey pbe, I think I got it not quite sure I understand why we need to us sslength and get the block's insertion point. But it does work. Thank you very much for you time. (defun c:ee (/ pea $blk block ll ur objs p1 p2) (vl-load-com) (setq pea (getvar 'Peditaccept)) (setvar 'PeditAccept 1) (if (setq $blk (ssget '((0 . "insert")))) (repeat (setq i (sslength $blk)) (setq pt (cdr (assoc 10 (entget (setq block (ssname $blk (setq i (1- i)))) )))) (vla-getboundingbox (vlax-ename->vla-object block) 'll 'ur) (command "_.erase" block "") (setq objs (ssget "C" (setq p1 (vlax-safearray->list ll)) (setq p2 (vlax-safearray->list ur)) ) ) (if (eq (cdr (assoc 0 (entget (ssname objs 0)))) "LWPOLYLINE") (command "_.pedit" "_m" objs "" "_join" "_Joint" "_Both" (distance p1 p2) "" ) (command "_.join" (ssname objs 0) (ssname objs 1) "") ) );repeat );if (setvar 'PeditAccept pea) (princ) ) Quote
