pedro gonçalves Posted October 9, 2012 Posted October 9, 2012 Hi everyone, I have this drawing, wich has a xref that simply won't bind... I've done some research and there's nothing like the message that appeared to me on the command line... It says: Quote Error: At least one of the specified xrefs failed to bind for an unknown reason. Though it says one of the specified xrefs, i only wan't to BIND just one. What happened and what can i do? I've runned PURGE and AUDIT and checked for xrefs within that xref (there was none), and nothing worked... Regards from Portugal Pedro Gonçalves Quote
pedro gonçalves Posted October 9, 2012 Author Posted October 9, 2012 Hi again everyone, Sorry for the double post, but i solved it already. I opened that xref and runned AUDIT, PURGE and OVERKILL so i could correct as many errors as i could. In the end i runned AUDIT and PURGE on the main drawing in wich that xref was attached once more and this time it worked once i've tried to BIND the xref. Thank you all anyway Best Regards, Pedro Gonçalves Quote
RobDraw Posted October 10, 2012 Posted October 10, 2012 There is a lot to be said for file maintence, especially AUDIT. Errors have way of sneaking into drawings. Quote
mateen Posted October 12, 2012 Posted October 12, 2012 Always use audit command its go0d for drawing health...but recover is the last hope for safe drawing... Quote
pedro gonçalves Posted October 15, 2012 Author Posted October 15, 2012 RobDraw said: There is a lot to be said for file maintence, especially AUDIT. Errors have way of sneaking into drawings. Surelly yes. This is an example to your statement. I just had to AUDIT the drawing and it worked after it. mateen said: Always use audit command its go0d for drawing health...but recover is the last hope for safe drawing... Yes, but if you are careful with your drawing, nothing happens that cannot be solved with two or three drawing utilities. Thank you all for the advice Best regards, Pedro Gonçalves Quote
neogreen Posted October 8, 2024 Posted October 8, 2024 On 10/9/2012 at 5:29 PM, pedro gonçalves said: Hi again everyone, Sorry for the double post, but i solved it already. I opened that xref and runned AUDIT, PURGE and OVERKILL so i could correct as many errors as i could. In the end i runned AUDIT and PURGE on the main drawing in wich that xref was attached once more and this time it worked once i've tried to BIND the xref. Thank you all anyway Best Regards, Pedro Gonçalves Expand 덕분에 해결했어 고마워 친구!! Translation Quote Thanks dude, I solved it, thanks dude!! Quote
