Please find the attachments and i want to mark the handles which are available in .CSV file
(55A75
55A63
55A60
55A40
55983
558B8
558B7
558B6
557FC
557D9
557D8
55794
55793
55772) in auto cad file in error layer.
Example.dwg
Example.csv
  • Replies 23
  • Tharwat
    7
  • crisraj99
    7
  • satishrajdev
    4
  • pBe
    2
(55A75
55A63
55A60
55A40
55983
558B8
558B7
558B6
557FC
557D9
557D8
55794
55793
Example.csv
Example.dwg
Wow thank you very much alanjt it's working now.
You're welcome.
  • 9 years later...
On 5/13/2013 at 4:39 PM, alanjt said:
Here's one I wrote a while back...
(defun c:LBL (/ foo AT:GetSel _pnts _pline _lwpline _dist e1 e2)
 ;; Draw (LW)Polyline between two selected curves (at midpoint of vertices).
 ;; Alan J. Thompson, 09.29.10
 (vl-load-com)
 (defun foo (e)
   (and (wcmatch (cdr (assoc 0 (entget (car e)))) "LINE,*POLYLINE,SPLINE")
        (not (vlax-curve-isClosed (car e)))
 (defun AT:GetSel (meth msg fnc / ent)
   ;; meth - selection method (entsel, nentsel, nentselp)
   ;; msg - message to display (nil for default)
   ;; fnc - optional function to apply to selected object
   ;; Ex: (AT:GetSel entsel "\nSelect arc: " (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "ARC")))
   ;; Alan J. Thompson, 05.25.10
   (while
     (progn (setvar 'ERRNO 0)
            (setq ent (meth (cond (msg)
                                  ("\nSelect object: ")
            (cond ((eq (getvar 'ERRNO) 7) (princ "\nMissed, try again."))
                  ((eq (type (car ent)) 'ENAME)
                   (if (and fnc (not (fnc ent)))
                     (princ "\nInvalid object!")
   ent
 (defun _pnts (e / p l)
   (if e
     (cond ((wcmatch (cdr (assoc 0 (entget e))) "ARC,LINE,SPLINE")
            (list (vlax-curve-getStartPoint e) (vlax-curve-getEndPoint e))
           ((wcmatch (cdr (assoc 0 (entget e))) "*POLYLINE")
            (repeat (setq p (1+ (fix (vlax-curve-getEndParam e))))
              (setq l (cons (vlax-curve-getPointAtParam e (setq p (1- p))) l))
 (defun _pline (lst)
   (if (and (> (length lst) 1)
            (entmakex '((0 . "POLYLINE") (10 0. 0. 0.) (70 . ))
            (foreach x lst (entmakex (list '(0 . "VERTEX") (cons 10 x) '(70 . 32))))
     (cdr (assoc 330 (entget (entmakex '((0 . "SEQEND"))))))
 (defun _lwpline (lst)
   (if (> (length lst) 1)
     (entmakex (append
                 (list '(0 . "LWPOLYLINE")
                       '(100 . "AcDbEntity")
                       '(100 . "AcDbPolyline")
                       (cons 90 (length lst))
                       (cons 70 (* (getvar 'plinegen) 128))
                 (mapcar (function (lambda (p) (list 10 (car p) (cadr p)))) lst)
 (defun _dist (a b) (distance (list (car a) (cadr a)) (list (car b) (cadr b))))
 (if
   (and
     (setq e1 (_pnts (car (AT:GetSel entsel "\nSelect first open curve: " foo))))
     (setq e2 (_pnts (car (AT:GetSel entsel "\nSelect next open curve: " foo))))
     (not (initget 0 "Lwpolyline Polyline"))
     (setq *LBL:Opt* (cond ((getkword (strcat "\nSpecify line to draw: [Lwpolyline/Polyline] <"
                                              (cond (*LBL:Opt*)
                                                    ((setq *LBL:Opt* "Lwpolyline"))
                           (*LBL:Opt*)
    ((if (eq *LBL:Opt* "Lwpolyline")
       _lwpline
       _pline
      (vl-remove nil
                 (mapcar (function (lambda (a b)
                                     (if (and a b (not (grdraw (trans a 0 1) (trans b 0 1) 1 1)))
                                       (mapcar (function (lambda (a b) (/ (+ a b) 2.))) a b)
                         e1
                         (if (< (_dist (car e1) (car e2))
                                (_dist (car e1) (last e2))
                           e2
                           (reverse e2)
 (reverse e2)
(vla-Regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport)
hi ,
Added to the last part
 (vl-load-com)
 (defun foo (e)
   (not (vlax-curve-isClosed (car e)))))
  (while
    (setvar 'ERRNO 0)
    (setq ent (meth (cond (msg) ("\nSelect object: "))))
    (cond
       (princ "\nInvalid object!"))))))
  ent)
  (if e
   (cond
     (list (vlax-curve-getStartPoint e) (vlax-curve-getEndPoint e)))
      (setq l (cons (vlax-curve-getPointAtParam e (setq p (1- p))) l)))))))
 (defun _pline (lst)
  (if
   (and
    (> (length lst) 1)
    (entmakex '((0 . "POLYLINE") (10 0. 0. 0.) (70 . 8)))
    (foreach x lst (entmakex (list '(0 . "VERTEX") (cons 10 x) '(70 . 32)))))
   (cdr (assoc 330 (entget (entmakex '((0 . "SEQEND"))))))))
   (entmakex (append
     (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 90 (length lst)) (cons 70 (* (getvar 'plinegen) 128)))
     (mapcar (function (lambda (p) (list 10 (car p) (cadr p)))) lst)))))
 (defun _dist (a b)
  (if
   (and
    (setq *LBL:Opt* (cond ((getkword (strcat "\nSpecify line to draw: [Lwpolyline/Polyline] <" (cond (*LBL:Opt*) ((setq *LBL:Opt* "Lwpolyline"))) ">: "))) (*LBL:Opt*))))
   ((if (eq *LBL:Opt* "Lwpolyline") _lwpline _pline)
    (vl-remove nil
     (mapcar (function (lambda(a b)
    (mapcar (function (lambda (a b) (/ (+ a b) 2.))) a b))))
       e1
      (if (< (_dist (car e1) (car e2)) (_dist (car e1) (last e2))) e2 (reverse e2))))))
 (princ))
