cyter Posted October 8, 2012 Share Posted October 8, 2012 The image below shows an electrical network with four elements, a current controlled source, a resistor, one current source and a voltage source. Although I haven't labeled them, there are 5 interesting nodes in the network. Four at the middle of each side of the square and one at the center. I've been having trouble designing the current controlled source in PSpice. Does any one have an idea on how I would go about designing the current controlled source in PSpice? Quote Link to comment Share on other sites More sharing options...
paisis123 Posted October 10, 2012 Share Posted October 10, 2012 I would simply make blocks of the individual symbols and then space them out evenly. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 10, 2012 Share Posted October 10, 2012 How would you go about designing the current controlled source below in AutoCAD? Does any one have an idea on how I would go about designing the current controlled source in PSpice? Your subject title and problem description do not make logical sense. http://www.electronics-lab.com/forum/index.php Is your problem with using AutoCAD or is your problem using PSpice? Quote Link to comment Share on other sites More sharing options...
