Lt Dan's legs Posted October 8, 2012 Posted October 8, 2012 I have a block that is inserting as a group. When i insert my block then explode it parts of the block are grouped. Does anyone have an inkling as to why this is happening. Also this is a networked file and is not occuring on anyone elses machine. Thanks Quote
RobDraw Posted October 9, 2012 Posted October 9, 2012 Check the pickstyle variable value to see if that is the difference. C:\Program Files\Autodesk\AutoCAD MEP 2011\Help\filesACR\WS1a9193826455f5ffa23ce210c4a30acaf-4efb.htm Quote
Lt Dan's legs Posted October 9, 2012 Author Posted October 9, 2012 Problem solved. Thank you for your help Quote
