Hatman Posted October 4, 2012 Posted October 4, 2012 Hi, I have Autocad 2013. This is probably going to sound really stupid but I am having some problem trying to put simple through holes in a 3D drawing I am doing. I have a 2D drawing of a round plate with four holes in it. I want to render this in 3D and make the plate 12 mm thick and show the 4 holes which go through it, simple right? Following the video tutorials in Autocad 2013 I have changed to 3D modelling space, activated the SW Isometric view, Extruded the plate and made it 12 mm thick, all good so far. Now the problems.... I am able to extrude or push pull the holes and are able to create what appear to be the four holes in wireframe layout and when I change the setting to conceptual, the plate renders beautifully but the holes show nothing except a circle on the plate surface with no through hole. Change back to wireframe view and they are there! I am sure I am following all the correct steps. What am I doing wrong?? Appreciate any step by step advice. Thanks in advance. Quote
ReMark Posted October 4, 2012 Posted October 4, 2012 Post a copy of your drawing and someone here will take a look at it. This plate you made is it a 3D solid? Quote
nod684 Posted October 4, 2012 Posted October 4, 2012 Hi, I have Autocad 2013. This is probably going to sound really stupid but I am having some problem trying to put simple through holes in a 3D drawing I am doing. I have a 2D drawing of a round plate with four holes in it. I want to render this in 3D and make the plate 12 mm thick and show the 4 holes which go through it, simple right? Following the video tutorials in Autocad 2013 I have changed to 3D modelling space, activated the SW Isometric view, Extruded the plate and made it 12 mm thick, all good so far. Now the problems.... I am able to extrude or push pull the holes and are able to create what appear to be the four holes in wireframe layout and when I change the setting to conceptual, the plate renders beautifully but the holes show nothing except a circle on the plate surface with no through hole. Change back to wireframe view and they are there! I am sure I am following all the correct steps. What am I doing wrong?? Appreciate any step by step advice. Thanks in advance. were you able to subtract the holes from the plate? Quote
JD Mather Posted October 4, 2012 Posted October 4, 2012 Forget extrude, backup. Presspull the plate and holes all at the same time. Done! Quote
Hatman Posted October 4, 2012 Author Posted October 4, 2012 Thank You. I now have it figured thanks to your advice and have written the process for future reference. Quote
Hatman Posted October 4, 2012 Author Posted October 4, 2012 Yes mate, but with the plate 12 mm thick of course. If I go to the solid subtract button and follow the steps I got it happening, thanks Quote
ReMark Posted October 4, 2012 Posted October 4, 2012 So you forgot to subtract the holes? Yep. Been there and done that too a very, long time ago. Glad you got it figured out. Quote
JD Mather Posted October 4, 2012 Posted October 4, 2012 and have written the process for future reference. Written the process? Presspull. That's it, done. You have draw a rectangle. You draw circles. Presspull and click in area between the rectangle and circles and drag direction and type distance. Enter. Quote
ReMark Posted October 4, 2012 Posted October 4, 2012 Maybe he's writing a tutorial for the next unlucky person to venture down the AutoCAD path? Quote
Hatman Posted October 4, 2012 Author Posted October 4, 2012 Thanks JD, I did try the presspull and Wallaah!! Thank you mate. And yes REMark I did write the process down so I could look smart to my teenage kids Some of us do not use AutoCad too reguarly and I am learning to reride the horse again and having a lot of fun. Always appreciate the quickest way. Quote
JD Mather Posted October 4, 2012 Posted October 4, 2012 I figured out how to do something once and then lost my instructions for 3 years till one day I opened an old book for a previous release and found I had used it for a page marker. Quote
ReMark Posted October 4, 2012 Posted October 4, 2012 Nothing wrong with that although they are probably smarter than both of us and would have figured it out in about 5 seconds. LoL Have fun! Quote
