bdw_at_TDE Posted October 3, 2012 Posted October 3, 2012 Hi, When i use the command -attdef: -ATTDEF Enter an option to change [Invisible Constant Verify Preset Lock position Annotative Multiple lines]: so i can toggle the invisible mode with the code (command "-attdef" "I" "" ... ) now i would like to check te current state of this invisible mode to know if i have to toggle it or not something like: (if (= invisible-mode "n") (command "-attdef" "I" "" ...) (command "-attdef" "" ...) ) Quote
MSasu Posted October 3, 2012 Posted October 3, 2012 Please check the AFLAGS system variable. It store the current active modes as a sum; the value for Invisible is 1. By the way, please edit your post and add the required code tags. Quote
