Chandru Posted October 2, 2012 Posted October 2, 2012 Hello I am trying to make multiple find and replace all the texts (text, mtext, and texts in blocks etc) in model space through excel vba (and not through Autocad vba). I got the basic code from here and trying to modify for my requirements. http://forums.autodesk.com/t5/Visual-Basic-Customization/VBA-Find-Replace-Quick-Fix-for-Someone-not-me-Please-Help/td-p/1829444/page/2 I am able to do find and replace for text, but getting an error when trying to replace the text in blocks. Have checked some threads in this forum but yet to debug. -------------------- With oModel.Utility End with -------------------- I have attached the excel file in which the glossary is available in Sheet1 and macro in Module1. Have attached a sample drawing. Any help is appreciated. Thanks Chandru Drawing1.dwg Multiple Find and Replace in all Autocad drawings.xls Quote
ska67can Posted October 2, 2012 Posted October 2, 2012 The code you are using is to replace block attribute text. Your block doesn't have attributes, your block IS the text. Quote
Chandru Posted October 2, 2012 Author Posted October 2, 2012 ska67can - The text with a leader is in fact a block (Block name: BLK1) (that is how I received the drawing from the client). Others are text and mtext. The vba macro works well for the text, mtext and layer name. I am not able to debug the find and replace for block reference. I have made another drawing and this contains additional blocks. Still this vba is not able to find the attributes in the block. This is the code snippet where I am getting the error. I am not sure how to access the Utility. (Think that is where the block definitions can be accessed) With oAcad.ActiveDocument.Utility or With oModel.Utility I am able to manually open the Block editor, edit each block, find the text and replace it with the text in "replace text" column. But the number of drawings demand automation. Case "AcDbBlockReference" Set bRefObj = objEnt(intI) 'With oAcad.ActiveDocument.Utility 'With oModel.Utility If bRefObj.HasAttributes Then bRefVar = bRefObj.GetAttributes For intIBlk = LBound(bRefVar) To UBound(bRefVar) wksGlossary.Cells(1, 4) = bRefVar(intIBlk).TextString 'Temporarily Copy Text to Excel For intO = 0 To intRowCount - 1 strFind = wksGlossary.Cells(1 + intO, 1).Value 'Set Find text value textLen = Len(strFind) 'Determine the length of Find text C = wksGlossary.Cells(1 + intO, 1).Row 'Determine the location of Find text on Spreadsheet strRepl = wksGlossary.Cells(C, 2) 'Determine the Replace text based on location textPos = InStr(1, wksGlossary.Cells(1, 4).Value, strFind, 1) If textPos > 0 Then 'Match Found wksGlossary.Cells(1, 4).Value = WorksheetFunction.Replace(wksGlossary.Cells(1, 4).Value, textPos, textLen, strRepl) 'Replace Text bRefVar(intIBlk).TextString = wksGlossary.Cells(1, 4).Value intReplaced = intReplaced + 1 End If Next Next End If 'End With RenderMan - Thanks for the suggestion. I have searched this forum fully, have checked the Batch Find and Replace by Lee mac. Lee mac's lisp routine does not handle unicode characters. What I get from client is unicode characters in the text and block, and need to change that. I have made a detailed reply in that thread last year, found some bugs, and have made few suggestions. Here is the link. www.cadtutor.net/forum/showthread.php?46135-Batch-Find-amp-Replace-Text/page19 Thank you for your detailed feedback Chandru, it is greatly appreciated, I now have many ideas and bug fixes to implement in the next version.Thanks Lee Since Lee mac's lisp routine is no going to support unicode characters, and also to save in previous format, I decided to develop the vba routine. Thanks, Chandru Drawing2.dwg Quote
ska67can Posted October 3, 2012 Posted October 3, 2012 Yes, the text is a block but it is not a block attribute which is what your code is looking for. You need to edit the block itself, not the block reference. Try this: Dim oEnt As AcadEntity Dim oBlock As AcadBlock Dim i As Long, j As Long On Error Resume Next For Each oBlock In oAcad.ActiveDocument.Blocks For i = 0 To oBlock.Count If oBlock.Item(i).ObjectName = "AcDbText" Then For j = 1 To wksGlossary.Cells(65536, 1).End(xlUp).Row 'Sets the Search Range If oBlock.Item(i).TextString = wksGlossary.Cells(j, 1) Then 'Search for Original Text oBlock.Item(i).TextString = wksGlossary.Cells(j, 2) 'Replace Text oBlock.Update 'Save Block Definition End If Next j End If Next i Next oBlock On Error GoTo 0 BTW With ThisDrawing.Utility is completely unnecessary and isn't actually doing anything. I don't know why I put it in there in the first place. Quote
Chandru Posted October 3, 2012 Author Posted October 3, 2012 ska67can - Many thanks for the code. It works perfectly. I got the point, that we need to open the block and replace the text, and not the block reference. Appreciate for your code on find and replace. It is very simple and neat. I have used it for find and replace in text and mtext. Now working on find and replace in the 'text override' in all type of dimensions. Will update the macro for the community use once it is over. Thanks, Chandru Quote
BlackBox Posted October 3, 2012 Posted October 3, 2012 RenderMan - Thanks for the suggestion. I have searched this forum fully, have checked the Batch Find and Replace by Lee mac. Lee mac's lisp routine does not handle unicode characters. What I get from client is unicode characters in the text and block, and need to change that. I have made a detailed reply in that thread last year, found some bugs, and have made few suggestions. Here is the link. www.cadtutor.net/forum/showthread.php?46135-Batch-Find-amp-Replace-Text/page19 Since Lee mac's lisp routine is no going to support unicode characters, and also to save in previous format, I decided to develop the vba routine. I must have overlooked that requirement in the OP; glad you got it sorted. Quote
