chrisdarmanin Posted October 1, 2012 Posted October 1, 2012 when i fillet 2 lines acad shows where the lines intersect and the fillet will be. that snap icon is too small (ie one pixel). Can i fix that? thanks Quote
JD Mather Posted October 1, 2012 Posted October 1, 2012 (edited) Check your Options. Edited October 1, 2012 by JD Mather Quote
rkmcswain Posted October 1, 2012 Posted October 1, 2012 that snap icon is too small (ie one pixel). Can i fix that? thanks Maybe you are talking about the variable PICKBOX? Type that in and set it to a larger number. Quote
chrisdarmanin Posted October 1, 2012 Author Posted October 1, 2012 no its not the pickbox variable... btw using acad 2012 i'll post a couple of screeshots Quote
Dadgad Posted October 1, 2012 Posted October 1, 2012 It's not really a SNAP ICON, I don't think you can resize it. Do you mean the object tracking apparent intersection point, the X? Oh no, you mean in the lower image. Why does it matter, you can't change it, without redefining or modifying the geometry? Quote
chrisdarmanin Posted October 1, 2012 Author Posted October 1, 2012 the lower image is the bad one. it doesn't really matter but sometimes i find that the intersection point when filleting to be useful Quote
chrisdarmanin Posted October 1, 2012 Author Posted October 1, 2012 fixed... i changed the fillet radius to 0 is this normal?? Quote
Dadgad Posted October 1, 2012 Posted October 1, 2012 That is the same way it works on my 2012. It would seem to be more relevant when filleting to 0 radius, that you might want to see that point more clearly defined. Glad you figured it out. Quote
