Ahankhah Posted September 29, 2012 Posted September 29, 2012 Hi all, who knows a way to set current layer filter to built-in filters like: 'All' or 'All Used Layers', of course not manually but via vlisp. Thanks in advance Quote
VVA Posted September 30, 2012 Posted September 30, 2012 I klnow two commands Command _-LAYER options _filter (command "_-layer" "_filter") and (command "_+layer") I do not understand the behavior of the command "_+layer" Use the _-layer based localization to AutoCAD Russian localization for AutoCAD (command "_-layer" "_filter" "_set" "Все" "") AutoCAD for the English language (no check) (command "_-layer" "_filter" "_set" "All" "") Quote
Ahankhah Posted September 30, 2012 Author Posted September 30, 2012 Thank you very much VVA, I tried "All" and it worked. Indeed already I knew this way, but typed "all" and "all used layers" with no result, for Layer Filter names in AutoCAD are case sensitive, (i.e: "All" and "All Used Layers", but not "all" and "All Used Layers") I again appreciate your kind help:) Quote
