3rdElle Posted September 28, 2012 Posted September 28, 2012 Is AutoCAD capable of translating text (changing on the drawing) from one language to another? Quote
SLW210 Posted September 28, 2012 Posted September 28, 2012 Not that I am aware. If you find something, let me know. Quote
Tyke Posted September 29, 2012 Posted September 29, 2012 I have a VBA Routine that I wrote a few years ago that goes through each text entity in a drawing, zooms in on it and lets you do the translation directly. I did it that way so that you could see if the text fits. It just filters out the Text and MText entities, it would need modifying to do Attributes. I still use it occasionally but I don't do that much translation work directly in AutoCAD any more. I did see a lisp somewhere that got all the text out of a DXF file and let you translate it a text entity in a separate window. That didn't need AutoCAD either, but you never knew if the translated text fitted or if it overlapped. AutoCAD doesn't have the capability of doing the translation itself. What are you wanting to do? Quote
fuccaro Posted October 1, 2012 Posted October 1, 2012 How about this scenario: -Export all the texts from the drawing along with the insertion points and layers (and possible other info like style, orientation...) in a CSV file, using a simple Lisp -Open that file in Excel, copy-paste the column containing the texts in a new file -Pass that file to a translator or maybe even to Google translate (I never tried this) -Replace in the Excel file the column containing the text with the translation and save the file in CSV format -Plug back the text in the drawing using an other Lisp I used that years ago. When bringing back the text in the drawing I used different layer name so I was able to show the same drawing with the original texts or the translated ones, as requested. Quote
SLW210 Posted October 1, 2012 Posted October 1, 2012 How about this scenario:-Export all the texts from the drawing along with the insertion points and layers (and possible other info like style, orientation...) in a CSV file, using a simple Lisp -Open that file in Excel, copy-paste the column containing the texts in a new file -Pass that file to a translator or maybe even to Google translate (I never tried this) -Replace in the Excel file the column containing the text with the translation and save the file in CSV format -Plug back the text in the drawing using an other Lisp I used that years ago. When bringing back the text in the drawing I used different layer name so I was able to show the same drawing with the original texts or the translated ones, as requested. I use a copy/paste into Babelfish translater and then copy/paste back to AutoCAD. Next time, I'll see how that method works. Quote
hoss Posted October 1, 2012 Posted October 1, 2012 have a look at this http://apps.exchange.autodesk.com/MEP/2013/en/Detail/Index?id=appstore.exchange.autodesk.com%3aCOINS-Translate%3aen Quote
Tyke Posted February 15, 2016 Posted February 15, 2016 If there is still any interest in translating the text in drawing check out this link: http://www.cadtutor.net/forum/showthread.php?95408-Translating-drawings&p=654267#post654267 Quote
