jmos4 Posted September 26, 2012 Posted September 26, 2012 I have been using Autocad and Mechanical 2012 and just went to 2013 The Refedit use to have a dialog box that would allow you to rename, change base point before exiting Is there a system variable to allow for this to come up?Regards, Jim Quote
Dadgad Posted September 26, 2012 Posted September 26, 2012 Welcome to the forum. I have never used MECHANICAL, nor have I ever seen this dialog, my guess is that it is only available in the verticals. Could be wrong though. Quote
jmos4 Posted September 26, 2012 Author Posted September 26, 2012 I use to get this I primarly use Mechanical and with 2012 I would get that dialog box which let you redefine the name and insertion point before exiting. 2013 Mechanical and Normal Acad you get the following. so I want to know does someone know the variable or is there a patch to allow this dialog to be accessed, I cant understand why Autodesk would remove a feature like this as the other work arounds are very time consuming. Regards, Jim Quote
