How to paste values without clicking on command line?
Hello to all,
In office this is working fine, after copying a value in clipboard like "1566.78" when I want to draw a line while my cursor is on my drawing space I write "0," and then hit "Ctrl+v" it draws line point on "0,1566.78". But this is not working fine in my home Cad, When I draw a line in same procedure and when I hit "Ctrl+v" after writing "0," it pastes the value "1566.78" as a text. To do this right I have to click on command line to draw a point but in office I don't have to click on command line. I also import the office profile *.ARG in home Cad but still not working.
Does someone know how to fix that?
Thanks.
You should also import the .svf (system variable file), and in that way it would probably work, as this is not caused by a PROFILE issue,
but a SYSTEM VARIABLE setting.
It may be your DYNMODE or your DYNAMIC INPUT DRAFTING SETTINGS, both are shown in the images. :)
Hi Dadgad,
I did as you told but still it is not working. I didn't import .svf file because I don't know how to import that. I am using AutoCad-2007 on both systems.
Any other idea?
