Lee Mac Posted September 23, 2012 Posted September 23, 2012 When ellipsis (...) are used in the thread title of threads containing multiple pages, users will encounter the following 403 (Forbidden) error when attempting to view all but the first page: To provide an example to illustrate this behaviour, try viewing the second page of the following thread: http://www.cadtutor.net/forum/showthread.php?72884-convert-list-with-mapcar-lambda.... To circumvent the error, users can remove the thread title from the URL; for example, by removing the highlighted section in the following URL, the second page may be viewed: http://www.cadtutor.net/forum/showthread.php?72884[highlight]-convert-list-with-mapcar-lambda....[/highlight]/page2 However, to prevent this issue from arising in the future and to reduce the work for the forum moderators, is there any way to implement a restriction on the use of ellipsis in thread titles for newly created threads? Quote
fuccaro Posted September 24, 2012 Posted September 24, 2012 Lee I clicked the link you posted - at this end it works just fine. I can't remember if I ever posted thread titles containing ellipsis, but if that causes errors to others, I will avoid doing that in the future. Quote
Tyke Posted September 24, 2012 Posted September 24, 2012 I tried your link today Lee and got the "Forbidden" error message too. Quote
Dadgad Posted September 24, 2012 Posted September 24, 2012 In user PROFILE under GENERAL SETTINGS one can elect to show 5, 10, 20, 30, or 40 posts per page. This obviously wouldn't fix anything, but choosing 40 would ameliorate the problem somewhat. I am just guessing, not sure, that the default might be 10 posts, based on the OP's statement in that thread that he couldn't see the 11th post. It certainly seems like it would be a simple data validation issue to fix, in the NEW THREAD title field, eh? Quote
CADTutor Posted September 24, 2012 Posted September 24, 2012 This is a known issue with the current version of vBulletin software. The 3 dot ellipsis is perfectly OK in thread titles. The problem arises when the OP uses more than 3 dots (periods). 4 dots or more will result in the 403 Forbidden error. The best solution for now is for OPs to use the ellipsis correctly (3 dots only) and for mods to correct any thread titles that are likely to cause this problem when they see them. For example, I've now corrected the thread title on the thread identified by Lee and it works just fine. Longer term, we are moving away from vBulletin and this issue will cease to be a problem. Quote
Lee Mac Posted September 24, 2012 Author Posted September 24, 2012 Thank you for your attention David, much appreciated. Quote
