Bobzy20 Posted September 21, 2012 Author Posted September 21, 2012 Oh yeah there is only one enlarged ringed section which is shown on the top view, good spotting! WE need it completed in AutoCAD because that’s all we know. Quote
JD Mather Posted September 21, 2012 Posted September 21, 2012 WE need it completed in AutoCAD because that’s all we know. Same technique previously suggested. (in any CAD program that I am aware of) Quote
Bobzy20 Posted September 25, 2012 Author Posted September 25, 2012 Trim extruded elliptical surface to the "belt-buckle" shape.Thicken. Sweep cut the "ribs". Add fillets. Might need some help with this one if you have any free time. Quote
JD Mather Posted September 25, 2012 Posted September 25, 2012 It might be a couple of days till I can finish this up - I'm trying to do in such a way that you can follow step-by-step sequence. Quote
Bobzy20 Posted September 26, 2012 Author Posted September 26, 2012 Looks good to me, thanks for your help. Quote
Bobzy20 Posted October 4, 2012 Author Posted October 4, 2012 Any progress with your tutorial - JD Mather? Quote
JD Mather Posted October 4, 2012 Posted October 4, 2012 I forgot about this one, been busy with other work. I'll try to get back to it, but you might have to bump the post a couple of times as I don't use AutoCAD much anymore. Quote
SEANT Posted October 6, 2012 Posted October 6, 2012 (edited) Here is an attempt via Nurbs Surface modeling. The process works fairly well but requires alot of attention/adjustments to ensure sufficient overlap for the SurfSculpt command. The inner voids were constructed with the more standard Boolean Operations and Fillets. Though, the fillets also required a bit of overlap tolerance. SurfBounds.dwg Final.dwg Edited October 6, 2012 by SEANT Corrected command name Quote
Bobzy20 Posted October 8, 2012 Author Posted October 8, 2012 Looks very nice, thanks for the input. Quote
