wishbonesr Posted September 19, 2012 Share Posted September 19, 2012 Adapting the brick hatch pattern to the curve is just fantastic. I need to design a curved brick paved sidewalk to my house just so I can use the lisp routine! Oh yeah! I want it just to learn the method in which something like that is accomplished. I mean... Is a new hatch created on the fly, is the hatch drawn with autocad and then blocked? Is the block then converted to a new custom hatch only in the drawing? Quote Link to comment Share on other sites More sharing options...
nod684 Posted September 20, 2012 Share Posted September 20, 2012 I'm writing ... unfortunately slowly because I have little time available. @ReMark: Thanks. An example of using, the hatch is adapted to the curves of destination and transformed into block. [ATTACH=CONFIG]37317[/ATTACH] wow! been looking for that all this time but to no avail! how did you do that?? that is so great! it really is!! Quote Link to comment Share on other sites More sharing options...
GP_ Posted September 20, 2012 Share Posted September 20, 2012 Thanks to all. The concept is: the hatch is composed of lines which are in a certain position with respect to the source lines, just find the position proportionally compared to the destination curves. So nothing exceptional. @BIGAL You can adapt any composition of lines that is not a hatch, but at the expense of speed, you should try layer and color of each line, but now is only done for the hatch. Quote Link to comment Share on other sites More sharing options...
nod684 Posted October 8, 2012 Share Posted October 8, 2012 when can we see the code? Quote Link to comment Share on other sites More sharing options...
paulmcz Posted October 8, 2012 Share Posted October 8, 2012 ;;; draws cardioid - animated (defun c:cdda (/ c ip p p1 pp r ai osn e e1 e2 oecho p2 ohl) (command "_.undo" "begin") (setq osn (getvar "osmode") oecho (getvar "cmdecho") ohl (getvar "highlight") r 2;(getdist "\n Radius?: ") ip (getpoint "\n Insert animated cardioid curve: ") ai (* (/ pi 360) 2.0) c 0 p1 (polar ip (+ pi (* c ai)) (* 2.0 r)) p (polar p1 (* 2 c ai) r) ) (setvar "cmdecho" 0) (setvar "highlight"0) (command "delay" 1000) (command "circle" ip r) (setq e (entlast)) (command "delay" 1000) (command "circle" (polar ip pi (* 2.0 r)) r) (command "delay" 1000) (setq e1 (entlast)) (command "line" (polar ip pi r)(polar ip pi (* 2.0 r)) "") (setq e2 (entlast)) (command "delay" 2000) ;;;********************************** (repeat 360 (command "delay" 20) (setq c (1+ c) p1 (polar ip (+ pi (* c ai)) (* 2.0 r)) p2 (polar p1 (* 2 c ai) r) ) (command "rotate" e1 e2 "" ip (/ (* ai 180) pi)) (command "rotate" e2 "" p1 (/ (* ai 180) pi)) (setq p p2) ) (repeat 360 (command "delay" 20) (setq c (1+ c) p1 (polar ip (+ pi (* c ai)) (* 2.0 r)) p2 (polar p1 (* 2 c ai) r) ) (command "rotate" e1 e2 "" ip (/ (* ai 180) pi)) (command "rotate" e2 "" p1 (/ (* ai 180) pi)) (entmake (list (cons 0 "line")(cons 10 p)(cons 11 p2)(cons 62 1))) (setq p p2) ) (repeat 360 (command "delay" 30) (setq c (1+ c) p1 (polar ip (+ pi (* c ai)) (* 2.0 r)) p2 (polar p1 (* 2 c ai) r) ) (command "rotate" e1 e2 "" ip (/ (* ai 180) pi)) (command "rotate" e2 "" p1 (/ (* ai 180) pi)) (setq p p2) ) ;;;********************************** (command "delay" 4000) (command "erase" e e1 e2 "") (setvar "osmode" 0) (setvar "cmdecho" oecho) (setvar "osmode" osn) (setvar "highlight"ohl) (command "_.undo" "end") ;(command "_.undo" 4) (princ)) Animated cardioid Quote Link to comment Share on other sites More sharing options...
GP_ Posted October 8, 2012 Share Posted October 8, 2012 when can we see the code? One day (or two). Quote Link to comment Share on other sites More sharing options...
teknomatika Posted October 8, 2012 Share Posted October 8, 2012 http://www.theswamp.org/index.php?topic=32789.0 Quote Link to comment Share on other sites More sharing options...
Tomislav Posted November 6, 2012 Share Posted November 6, 2012 ...just stumbled here and what do i find...a marvelous lisp...great stuff GP_....awaiting code Quote Link to comment Share on other sites More sharing options...
Costinbos77 Posted November 6, 2012 Share Posted November 6, 2012 Looking for interesting automations on commands via autoLISP. Nothing specific comes to mind. But if you have some cool ideas or want to challenge me to develop a command please leave a comment. Love designing via CAD and Max and want to better my tactics. Read this : http://www.cadtutor.net/forum/showthread.php?74605-No-DCL-window-or-Toolbar and if you have any ideas, I'm listening. Costin Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted November 6, 2012 Share Posted November 6, 2012 ...just stumbled here and what do i find...a marvelous lisp...great stuff GP_....awaiting code http://www.cadtutor.net/forum/showthread.php?73335-AlignH-Align-hatch-on-curved-path Quote Link to comment Share on other sites More sharing options...
